Running while car is off the ground
I have a Hum coming from the rear of the car. I changed the rear tires and still the same so it's not the tires. I want to put the car on jack stands and run the wheels at around 40 mph but I get all kinds of lights on the dash. My car does not seem to like it when the rear wheels are turning and the front are not. so how do I do this? When people Dyno their cars the rear wheels run rather quickly with the front wheels not turning, How do I get around this? Remove a Fuse? or what? HELP ME!
Don't worry about the DIC message, since you get the same message when dyno'd the car or running the trans to correctly fill it as well (front tires not moving). As soon as you drive the car on the road again, the message will be gone.
Just to make sure that you have the car supported correctly, since if it falls off the stands, its not going to be pretty.
OK Got it going to buy a 33 mm socket and remove the passenger side axle shaft and check the hub. Noise seems to be coming from this side. I'll let u know.
Hope this helps
So I have the car up on jack stands and with the wheels turning at 3000 rpm's the noise is coming from the passenger side rear wheel. I removed the hub and yes it is the culprit this bearing is kaput. No one has one in stock so i ordered one, should be here maybe Tuesday. Well one more issue put to rest. Thanx guy's for your Help.
Jstan2014 (03-20-2018)
