Method Of Flushing Just The Engine Block???
Car: 1966 327ci L79.
Objective: Flush JUST the engine block without starting engine. Coolant currently drained.
Reason: Now have radiator OUT . I have a new Dewitt’s radiator ready to install. I do not want to do a “normal” engine running system flush after installation causing engine block scale /contaminants to run through new radiator and other new non contaminated heating and cooling components.
Situation: Old coolant drained years ago and engine not run due to repairs. NEW radiator and NEW heater hoses are disconnected. NEW water pump installed. New heater core.
QUESTION: Can I “effectively” flush just the engine block of scale and contaminants by running a water hose flow through the thermostat entry point thus exiting the lower water pump hose connection??? Is there any and coolant system flushing enhancing solution that I should add to the flush???
THANKS for your consideration and valued advice.
St. Jude Donor '07
normally, there are also small pipe plugs on the lower sides of the block that can be taken out too. if so you can poke around in there with something flexible to loosen and flush anything laying down low in the block.
Bill
Bill
The answer to your question is yes, remove the block drain plugs as mentioned above and plug the remaining openings so water will drain out through the block plugs. IMO, that will be more than sufficient to ensure everything is clean enough and it's about all you can really do, it will be fine.
Received 1,843 Likes
I doubt you'll get much of anything out by sticking a hose in the thermostat opening and trying to flush out of the water pump.
If it was me, I'd pour the cooling system full of white vinegar after I tied the top/bottom radiator outlets together. Let it sit awhile and then start the engine to agitate it and get it hot. Let it cool and repeat. Takes a couple of days to work. Drain the block out through the two bottom plugs above the pan rail and flush well with plenty of water. The holes in the bottom of the block will probably be plugged so you'll have to poke around to clear them.
Even better is oxalic acid (wood bleach) and washing powder. It used to be sold as cooling system flush. It works the same as vinegar only much quicker.
Also, saw on TV recently that a company (I think it is Evapo-Rust), is making a coolant descaler that you pour into the engine, run it for a few minutes, and drain the system. I can't remember the exact name of the product, but check with your local parts store - they may be able to guide you to the right product.
Phil
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
The only true way to get rid of the corrosion of years in the block recesses is to PULL the motor, knock out the freeze plugs and poke around to get into the corners as much as you can, and maybe steam clean with a hi temp pressure washer in all those openings. Otherwise you're just whistling dixie.
And nix on the solvent/vinegar soak unless you want to dissolve or soften gasket material and perhaps get future problems with leaks.
BTW - somebody had replaced those plugs with radiator-style petcocks on my '61...
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Brass won't rust in like steel will. I agonized over the issue and went with stainless steel with anti-seize. Teflon tape would probably be OK, too.
2023 C1 of the Year Finalist - Modified
Engine flush.
Block drains.
Getting the block drains out is an issue. I usually give them a "crack" with a small light hammer with more velocity than mass. Just tap them a couple of times. Then sometimes I apply a little heat, Map gas will work, get them pretty hot and smack them a couple more times. When they are out I always install drain valves. There are some nice ball valves that will thread right in, or even the radiator style butterfly valve will work. Then you can drain and flush easily.
There is a descaling solution that is sold by Detroit Diesel parts shops which is used for flushing those engines (two cycle DDs). It works very well, and also smells bad to say the least. You might look into that. I would favor pulling the freeze plugs as noted, but I would get the engine up to temp with a cleaner in the cooling system first and loosen as much as possible that way. Short of pulling the engine and soaking the block, which you don't want to do, using a cleaning solution and then draining it through the freeze plugs is the best answer.
Well, we just did it in another car. But maybe it isn't possible with his car. We just did it in my GT40, but that is not the same engine. My mistake.
Received 3,443 Likes
I would suggest using any of the different options of additives to clean the block and so on. I do not have one specifically that I recommend.
The reason is that when I go and install new parts much like what you are doing..I have already cleaned the system and got it as clean as it is going to get due to most of my customers do not want me to pull freeze plugs. Any remaining residual scale is so minute it is not going to effect the cooling system.
If your block drains are Allen head set screws....I use valve lapping compound when I insert the Allen wrench so the grit of the lapping compound helps fill in the looseness of the Allen wrench and also provides a bit more 'bite' so you do not round off the Allen wrench. Using the previously mentioned 'tricks' may be needed also.
And for whatever this is worth...I prefer using the socket head style hex head brass pipe plugs also. You do not have to tighten the living heck out of them to get them to seal. With or without Teflon tape on them I also like the steel ones like what the factory used in later years and ALWAYS use six point socket on them...regardless if they are steel or brass.
DUB
DUB
Don't know the affect it would have on an assembled engine, but I've been using EvapoRust to clean the water jacket in heads and block. I use dumdum to plug the intake holes in the head and keep the face flat up. Fill it with Evaporust and after a day or so, pour it out. Looks like new cast iron. On the block with it on the engine stand, tilt till block head is up, flat, level, dumdum on the waterpump inlet, small pipe extension with cap on the side block drain. Fill it level full, wait a day or so, drain and flush. Rinse and repeat the other side.
The block and heads water jacket will be as clean as the day it was cast.
DUB
It's pretty important to try to get the block drain plugs out. We had an old 350 in a C1 that was overheating so we went after it. We thought we finally had it cleaned enough to install a new radiator after flushing it several times several different ways including removing the water pump. Thankfully, we decided to get the car up in the air and get under it to get those plugs out. There was a lot of sediment and crap settled in the block that normal flushing didn't move. We used a pipe brush through the hole working it in and out to get the debris moving.
