Check out our Performance C5 Trans/Diff Mount!
Supporting Vendor
LUX Trans/Differential mount (LUX TDM)
Designed for the C5 Corvette, SacCityCorvette’s SuperDuty LUX TDM will stabilize the C5 Corvette Trans/Diff and help eliminate drive train shutter that feels like wheel hop. The LUX TDM has a large amount of Polyurethane to minimize noise and vibration making it comfortable for street driving yet stout and firm enough to keep the Trans/Diff stabilized during hard launches, power shifting, racing or just spirited driving. The stock rubber mount is very soft and allows a substantial amount of movement especially with any type of power adders and Drag Radials/Slicks. Keep that Trans /Diff where it belongs with the LUX TDM!
Powder Coated for protection.
Grade 8 & 10.9 Hardware for strength.
Installed with your factory 2 nuts & 2 bolts.
Made In The USA!
For more info
http://www.saccitycorvette.com/C5LUXMount.html
Made In The USA!
For more info
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
The following 3 users liked this post by SacCityCorvette:
Looks like another quality product from SacCityCorvette,
if I didn't already have the Pfadt brace I would be getting
one to go with your engine oiling improvement products
that I have.
that I have.
The following 2 users liked this post by Navy Blue 210:
BABYBUGY (02-01-2021),
SacCityCorvette (03-17-2022)
Supporting Vendor
ArmchairArchitect (05-27-2022)
Can you explain in more detail how this mount handles drive train shutter? It appears to allow some front to back rotation but attempts to limit side to side? Other mounts on the market appear to either stiffen all movement directions or limit side to side rotation from a wider foot print against the cradle like the c6 design. I have not seen any other mount allow front to back like this one. I would be happy to test this mount if needed as I see some wheel hop from a headers only Z06 and have been looking at the various mounts offered.
Supporting Vendor
Our LUX Mount helps eliminate the drive train shutter by being stiffer then the soft stock mount. We experimented with different durometer polys to get the best to keep noise and vibration down and still keep it very stable without it being like a semi solid mount. It also has less movement all around. We tested it on our 02 Zo6 doing hard launches, power shifts and normal driving to make sure we got it right.
If you are getting actual wheel hop a number of things can cause that. But when my C5 zo6 was having bad wheel hop it was the tires causing it. With the new tires burnouts and launches where smooth as silk.
Thanks
Christian
Supporting Vendor
https://www.saccitycorvette.com/Lux_...n_by_Derek.pdf
Supporting Vendor
We have the C5 Trans mounts in stock ready to ship if you need one.
https://www.saccitycorvette.com/C5LUXMount.html
Thank you,
Christian
__________________
Thank you,
Christian
__________________
Received 2,708 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
I purchased the LUX Trans/Differential mount for my black 99 (620 hp) and it really helped with wheel hop.
The following 3 users liked this post by knewblewkorvette:
Supporting Vendor
Supporting Vendor
Hi Everyone,
Just want to let you know that we have our LUX Transmission/Differential Mounts (TDM) in stock if you need
a performance upgrade or replacement for your flimsy stock mount.
Thank you
Christian
Thank you
Christian
Supporting Vendor
Hi Everyone!
We have the LUX Mounts ready to ship if you need one!
Thank you
Christian
Thank you
Christian
Night Owl for life
Received 3,247 Likes
I'm considering one of these. I put in an HPI mount but now I get gear whine.
I have read that situation has happened to others before and I would just as soon go back to a stock-ish design than have this whine on my DD.
Once you go to Pfadt, or any type of tranny mount like it, you will hear and feel noises you never heard or had.
I like it, but something to get used to.
The drivetrain will feel more planted, but you will have more cabin harmonics
