spark plugs and wires?
Received 19,299 Likes
'20-'21-'22-'23-'24
I use the AC Delco Iridiums and GMPP performance wires on my car - very happy with them.
Same setup and very happy with them. I changed out the plugs first and it just wasn’t running as smooth as I hoped after the engine warmed up. Decided to change out the wires because even though they looked okay, I didn’t know when they were installed (car had 124K miles). I swapped them out with the GMPP performance wires and it ran as smooth as a sewing machine. Great combo.
Received 3,054 Likes
NGK Iridium plugs and Taylor Thunder Volt 50 wires.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
FANCY high dollar Wires and plugs WILL NOT ADD HP/TQ.
A good quality plug and ignition wire will RESTORE the potential of what you already have.
Like others have stated, I use the GM Performance RED wires and AC Delco iridium plugs. Price, quality and performance are excellent
The GM Performance wires are well constructed, fit 100% and last a long time without any issues.
I don't like the MSD wires because the boots are very soft and tear easily.
Bill
Bill
Yello95 (03-21-2018)
Banned Scam/Spammer
Received 1,319 Likes
AC Delco makes basically the same plug with your choice of double platinum or iridium.
Iridium (part # 41-110) is less than $1 more than platinum (part # 41-962) so that's what we use. It can potentially help a rough running car better than platinum.
Received 1,261 Likes
I used the cheapo ngk tr5 in my car when it was stock/lightly modded and now use the tr6, both work great and are roughly $20 for a set of 8... not saying the delco iridiums are bad plugs, they aren't, but they also aren't 3 times as good as the ngk's in my opinion
