rebuilt or new trans for new engine
Cruising
Thanks for any thoughts
Dropping in a new 383 in my 71 vette. I currently have the original 350 automatic.
The new engine is going to have around 450HP so should i rebuild my current trans to handle that or buy a new one?
if so any recommendations on a trans that will fit in my car and work with a SBC 383 crate
thanks!
thanks!
Received 1,469 Likes
Cruise-In II Veteran
If your tranny is original, it should be a TH400.
I also went to a 383 stroker with similar horsepower and have an auto tranny and I decided to just rebuild it.
You can make it more stout by adding hardened sprags/races and add the TransGo shift kit.
Richard
Richard
I'm not that far along. I'm doing a body-off restoration so I'm working feverishly on the components in the engine compartment so I can mate the two back together.
I don't anticipate too many vacuum issues since I'm converting to electric headlights and getting rid of cruise control, so I only need vacuum for tranny, power brakes, and AC/heater controls I believe.
Also, my cam is fairly mild to make the car more streetable.
Richard
Richard
St. Jude Donor '22
the ole preventative maintenance
question.
i would consider an overdrive tranny.
and if not i would have it built with better
parts.
new engine deserves the peace of mind of a good tranny.
now if it was a stock deal and time and money were in play,
i would have to evaluate the orig trans for milage
etc.
question.
parts.
etc.
I did it just the opposite, went from an auto to a 5 spd Tremec so I figured it needed a new motor. Got a crate motor, new 5 spd trans, all new brakes master cylinder to rotors including lines, new p/s pump,cylinder and lines, so the only thing that can fail me now is the rear...ha..ha...right..
If it helps in terms of you making a decision, I rebuilt my TH350c with TransGo shift kit and hardened parts with all the internals rebuilt and including a new torque converter for around $800
Richard
Richard
Cruising
thanks for responses.....I think I am going to just do a rebuild. Money isn't the biggest thing for me it more about reliability and performance. I have had this car now for 7 years and in that time I have run into a few times when putting on new parts that they say just fit right in never goes that easy. I figure just having it rebuild with top of the line parts is the way to go .
UNLESS...someone here knows 100% of a new one that will fit perfectly and handle the performance and reliability i want
I'm running a 383 stroker pushing a little more HP and using the original TH400 with no issues. Make sure you match your motor with a good stall converter. I'm using a 2800 stall in mine. Good luck!
question.
parts.
etc.
question.
parts.
etc.
