65 Power Antenna Switch
Has anyone repaired a power antenna switch on a 65? The previous owner thought it was a good idea to place mine (his at the time) in a bucket with other piece parts (mostly nuts and bolts) and let it rain on it. Took me an hour just to get the outside of the chrome halfway cleaned....pitted.
The switch barely moves to the Up or Down position and doesn't seem to come back to the center position by itself. Since I've never seen a good one, is that normal?
Hoping I can get it all good and cleaned up tomorrow or this weekend.
Thanks for any advice,
Dex.
Dex.
it should come back to center on its own, sounds like its loaded with gunk, you might get it cleaned up with an electrical contact cleaner.
Thanks,
Dex.
I would be careful about the type of grease to use, clean it up with an electrical contact cleaner than use a dielectric grease, something that wont promote tracking of electric current.
Dex.
Dex.
BTW, just connected the speedo cable, under the car, WHAT A PAIN THAT WAS!
Thanks,
Dex.
Received 6,943 Likes
2015 C2 of Year Finalist
Soak it in WD40 And see what happens.
I would say so there is only so much you can do to save some parts
