Shear tunnel
Shear tunnel
So I hit a small speed bump in my subdivision and bent the shear tunnel up a bit and now it rubs my exhaust a bit and it's annoying me. I've tried searching for one at several places but can't find one. Any idea where I can get one. Thanks!!
JonMN (03-23-2018)
Are you talking about the tunnel plate pictured below? I removed mine when installing a Corsa exhaust system. If so, you might be able the just straighten it out.
Yes that's the one. The front leading edge is slightly bent up so it hits the exhaust every once and a while. I can probably live with it but if it's cheap enough I'll replace it.
I saw a used one on EBay for $50. Try Cultrag or Trunk Monkey...
Received 2,093 Likes
I'm kind to absolutely try that first and see if I can bend it back. Just lookin in case I can't get it straightened out enough to stop hitting. And I was curious to see how much they were just in case.
Most any garage, or sheet metal shop, or machine shop can easily correct that panel. Save that money you would have spent on a new plate for some cool mods.
Received 8,919 Likes
3 lb sledge and you will have it straightened out.
Bill
Bill
