WTB: Ls3 Heads
LS3 Ported or Aftermarket Heads
Looking for something along the lines of ported ls3 heads or tricks if the price was right. Located in Frederick MD, but am often in the Raleigh NC and Houston TX areas as well.
I live in Houston and I've decited to sell my new GMPP LS3 heads that have only been taking out the box to look at.
I'm going to need bigger heads and I have to mill the heads to raise compression for my L99. For that I need better valve angles. Im going for over 500rwhp with a L99 and an A4. It will not be easy.
OK....by next week, I should have the following coming off my '95 Impala:
1. CNC'ed OEM heads ported by Texas Speed;
http://www.texas-speed.com/p-1388-pr...d-porting.aspx
2. They are fitted with Comp Cams Ultra Pro-Magnum 1.8 rockers;
3. PAC-1204X (good to .700" lift) valve springs with Titanium retainers.
http://www.texas-speed.com/p-5680-pa...pring-kit.aspx
4. Valve Cover Spacers will come with these items.
http://www.texas-speed.com/p-884-umi...r-spacers.aspx
5. If I have to use different pushrods.....you can have the rods on the engine now.
6. All items, 1 through 3, have about 11,500 miles on them.
PM me if interested in the package.
KW
KW
4. If I have to use different pushrods.....you can have the rods on the engine now.
5. All items, 1 through 3, have about 11,500 miles on them.
KW
KW
