1969 rear window storage tray repair possible ?
Hello Together,
I got a question regarding the rear window storage tray.
Mine has a crack through the complete length, but still holds together. Its a 69 so not the fiberglasversion.
Is there a possibilty to repair this crack for example to add some layers of fiberglass ?
I tried to search this forum but did not find a repairsolution
If you increase the thickness of the frames you run the risk of the doors not closing. It's a tight fit to begin with, on my 69 even when one of the screws starts backing out the door wont close. Super glue works good. T
Thanks Terry, but I think you are at the wrong position, I mean this part.
The picture is from Alan, I hope its ok for him
Received 2,878 Likes
Hi Roma,
People are having success repairing the fiberboard storage tray in the jack compartment. But, those repairs are more cosmetic than structural.
Is the window storage tray the same material?
I'm not sure how the crack could be repaired to withstand the stresses put on the tray when it's used though..... as it's being clipped and unclipped.
Regards,
Alan
Regards,
Alan
Hi Alan,
tomorrow I will remove it and take a picture , the material is more like cardboard.
Thanks
Frank
Thanks
Frank
I myself, have added fiberglass reinforcement over the cardboard glove box liner, to add strength to mount a battery cut-off switch. It worked very well.
Hi R,
Knowing the limitations of the material that tray is made from I'd think a repair is going to be difficult.
It looks to me like a reinforcement is going to have to be made that spans the crack on each side and can be bonded in place.
I think this can be accomplished, but the 'cosmetic' result will be noticeable.
Regards,
Alan
Regards,
Alan
Not sure I`d call that a crack... it`s about broken in two. I`d keep my eyes open for another one. They come available now and then.
edit.... There`s one posted now in the C3 parts wanted / for sale section. It`s from a 72.
Meanwhile it is broken in 2 pieces but nevertheless I started the try with fiberglass . Finished 2 sections on the upper side.
I hope at the end of the weekend I have finished all sides and it works for a few more years
WOW It took a while to get into it ! I would do the same on both sides ,and add some alloy strip down each side to help strength (not original now anyway ! ), you have nothing to loose and maybe as you said it will last some more years.
I have one here that has bowed badly , I have it under a box of stuff trying to flatten it back again.
Good luck
Good luck
Im surprised replacement plastic ones haven't been made. They wouldn't be stock but they would be close and the probably would be stronger and not to difficult to make. Is it only 4 years that had the cardboard ones? 68-72? Than they went slight different and plastic ?
The one I repair is only 68 + 69
starting 70 was another version
https://www.ebay.com/itm/1970-72-Cor...gAAOSw8b9bk22R
You are giving it one last 'shot' before throwing in the towel on that old part. KUDO's to you for trying. I hope you are successful. If not, look for a '70 and later version that is more sturdy.
First shot finished
How it starts
After rework and a carefull sanding
And result
I should have done more sanding but I was a bit afraid to sand the original cardboard to hard
How it starts
And result
