FS: Fully Restored & Upgraded 1985 Corvette C4 w/Z51 Package - 7 speed - PRICE DROP
SOLD-$6900 Fully Restored & Upgraded 1985 Corvette C4 w/Z51 Package -7 speed
Just reduced. I'm selling my fully restored and upgraded Z51 1985 Corvette C4 with 7 speeds (4+3 Overdrive Doug Nash Transmission - 1987) manual transmission. I'm the second owner of this car. The car had been in garage storage for over 22 years when I found it and decided to restore it and is garage stored today. I rebuilt this car to keep it. I had it listed before but was in no rush, now I need to sell because I had an unanticipated emergency surgery and the bill is outrageous!
The engine and car was rebuilt from the ground up and used all OEM parts. I will also include all documentation (original purchase documents and work from first owner), receipts (for part warranties) and photos of the restoration process. Finally, I will include the original Corvette saw blade wheels that came with the car.
When I purchased the car had 162,685 miles and all of the fiberglass panels were in tact and no cracks. Current milage after 3 years is 163,867. Driven less 1,200 miles on a complete engine and car rebuild.
CLEAN TITLE. CLEAN HISTORY
Like all restoration projects I underestimated and overspent ( almost $15,000 in new parts and upgrades). The project took almost 2 years. The car has only been driven 1,182 miles after the engine rebuild and restoration. The car is currently garaged and driven sparingly for upkeep ( a couple of blocks every few weeks).
During the restoration process I kept the integrity of the car with improvements to performance. This includes an underdrive pulley kit and AIR pump delete along with porting the intake plenum, and an Edlebrock High-flow intake manifold for improving airflow from the air box. This will be one of the nicest and cleanest 30-year-old Corvette's you'll find. This car handle's like on rails and with an open exhaust has a great sound and fast pick-up. Many, Many Extras
Engine: - Chevy 350 Small block engine TPI. A complete rebuild but kept the original pistons, heads and block (work done by machine shop). Replaced valve springs, seals (fel-pro), rocker arms, pushrods, mild-cam, bearings, re-honed cylinders with no bore over. Work done by South Florida Machine Shop.,
New: timing chain, fuel injectors , Edlebrock aluminum valve covers, Edlebrock H-Flow Performance Intake Manifold, EGR, Ported and modified intake plenum, oil pressure sender, fuel pressure sender unit and pump, distributor HEI unit, Coil, MSD Ignition Cap and MSD Super conductor spark plug wires, shorty spark plugs and MORE
Braking: New; rebuilt brake calipers front and rear, rotors, brake pads, master cylinder, Stainless steel braided brake lines front and rear
Suspension & Steering: New; Front Polyurethane suspension bushings, Control arms upper and lower refurbished, upper and lower ball joints (Moog), New Front and Rear OEM Bilsetin Shocks ( Z51 Package), new rebuilt power steering rack, tires, 18" RUFF wheels -- (Will include original OEM saw blade wheels)
Cooling: New; Radiator motor fan, Oversized Performance aluminum radiator, radiator hoses, intake air temperature sensor, custom made high-temperature and flexible transmission oil cooler lines, A.C high temp and low temp switches.
AC: All new components; condenser, new evaporator canister, new blower motor, relays and hoses.
New Glass Targa Top -- OEM Blue Glass
New Headlamps and headlamp motors
New antenna motor -- fully retractable and automatic.
All new Interior.
Newly painted to Factory color ($4,500 in paint alone)
Exhaust: Melrose Smooth flow ceramic coated performance headers with "X" crossover pipes and Magnaflow C4 LT1 Catback Dual exhaust mufflers with tips
Transmission: 1987 Dough Nash 4+3 Overdrive transmission with new; drive shaft joints, fluids in transmission and rear axle, clutch, clutch slave cylinder
Electronic: New rebuilt ECM computer
MORE...
Price:$6900
All new Interior.
MORE...
Price:$6900
losburn (05-04-2018)
Well said
Indeed! The milage is really n the frame and body because EVERYTHING else is practically new or had been rebuilt. Thanks for reminder.
losburn (05-29-2018)
Received 3,043 Likes
St. Jude Donor '05
