C5 Forced Induction/Nitrous C5 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection, Meth
Rear mount alky reservoir
Old 04-04-2018, 11:35 AM
JustinJordan
Cruising
JustinJordan's Avatar
Default Rear mount alky reservoir
Looking for suggestions on a rear mount alky reservoir for my dual meth kit. I want to get the fuel out of the engine compartment. I've been told this is a potential fire hazard.
Old 04-04-2018, 11:38 AM
Turpid porpoise
Turpid porpoise's Avatar
https://www.corvetteforum.com/forums...meth-tank.html
Old 04-09-2018, 10:22 AM
nullpointer
nullpointer's Avatar
Originally Posted by Turpid porpoise
Not seeing any C5 options in that thread...
Old 04-09-2018, 10:50 AM
Turpid porpoise
You're probably not going to find any C5 specific options. I posted it to show what others are doing in similar situations.
Old 04-10-2018, 07:33 AM
Darkvette98
Darkvette98's Avatar
http://www.jdpmotorsports.com/manufa...anol-injection
I was looking at this one
Old 04-10-2018, 09:42 AM
06CobaltSS
06CobaltSS's Avatar
Used a snow tank, 7 gallon i believe.
Old 04-10-2018, 01:04 PM
corvettebob1
corvettebob1's Avatar
Sooo your worried about safety and you want to move the meth tank from the engine compartment where there is a firewall between you and the meth to inside the passenger compartment?
What could go wrong with that???
Old 04-10-2018, 06:33 PM
BURL
BURL's Avatar
Default Meth tank
The tank under the hood is meant to hold windshield washer fluid. Guess what windshield fluid is! Meth and water. So the OEM tank is meant to be alcohol resistant and is under the hood and away from the passenger compartment. Personally, I would want meth away from me and in the engine compartment as opposed to in the rear of the interior where it could rupture and spray the interior. It burns with an almost invisible flame so keep it outside of the interior of the car. Just my .02.
Old 04-11-2018, 01:32 PM
JustinJordan
Cruising
I think that there is far more risk of something bad happening with fuel in a make shift vented window washer tank near a hot engine than in a purpose built fuel cell in the back of the car.
Old 04-11-2018, 02:29 PM
ysb02
ysb02's Avatar
I'd keep it under the hood unless you want to wear a firesuit when you're in the car. A burnt out motor bay costs a lot less than an ICU burn unit stay.
Old 04-20-2018, 12:46 AM
Kingtal0n
Kingtal0n's Avatar
I mean, only run 50/50 or more water % and it shouldn't burn right? That would be safer I would think. But if you are going to use 100% methanol, yeah I agree it adds an element of danger that wasn't behind you before.
Old 04-22-2018, 11:34 AM
Mike04
Mike04's Avatar
I just purchased the tank below. Fit fine in the driver's rear compartment.
https://prometh.com/collections/tank...nt=43606496590
Old 04-23-2018, 11:11 PM
Tusc
Running Guns & Moonshine
Support Corvetteforum!
Tusc's Avatar
Received 3,284 Likes on 1,938 Posts
I have that exact tank which I purchased last year. It is brand new, never installed. I also have some high end tubing to run from the trunk to the engine bay which is braided. If you're looking for that tank, I'll sell mine for $200. I'll have to check in the garage what the tubing was but I remember it being about $80 worth and intended to not corrode with meth. If you want both, I'll do $250 plus shipping. I'm in CT.
Old 04-24-2018, 03:19 PM
TX Z06 02
TX Z06 02's Avatar
Thats the one I have as well. It is installed with the line running up the rocker panel to the alky control pump in the front fender well.
Did you put a switch on yours?
Old 04-25-2018, 05:39 AM
Mike04
Mike04's Avatar
Switch? I'm using a solenoid and a driver from alky control to open it if thats what your asking. Also the low level sensor.
Old 04-25-2018, 07:29 AM
TX Z06 02
TX Z06 02's Avatar
low level sensor is what I was referring to.
To Rear mount alky reservoir
Quick Reply: Rear mount alky reservoir
