Show Us Your Engines
There are numerous threads for our C3's classified for wheels, colors and builds.
How about a thread to show us your engines on the stand so we can see what we are all so proud of before they get dropped into the engine bay and all the work and components are hidden from view.
Just a couple photos with a list of components and what year C3 your dropping it into.
This is open to all make and model engines, full restorations, resto/mods or full performance.
Johns66 (10-03-2018)
Popular Reply
04-21-2021, 12:37 AM
Received 1,813 Likes
I even had those little spring clamps chrome plated...
STA70972
79 L82 took down to bare block, used the stock crank, rods and pistons after reworking. Dart iron heads, Sanderson shorties, Comp XE268 cam, Edelbrock intake, Lars tuned Q Jet.
Really woke it up. 4 speed and 3.70 rear end, goes pretty good.
twinpack (01-09-2019)
Received 3,219 Likes
HA- I don't think Summit or Jegs has mine-
Going in my 71 which originally was LS5 4 speed convertible
BMW V12
All Aluminum-painted Chevy Orange!!!
Stock had 326HP and 360 ft/lbs
about 328CI
10:1 Compression
Dry sumped
Custom Oil Pan
Individual Throttle Bodies
Custom intake runners
BMW V12
about 328CI
10:1 Compression
Dry sumped
Custom Oil Pan
St. Jude Donor '22
BMW V12
about 328CI
10:1 Compression
Dry sumped
Custom Oil Pan
BMW V12
about 328CI
10:1 Compression
Dry sumped
Custom Oil Pan
you have some fab skills no doubt.
even the nasty bmw in a vette factor was ok since it is a 12 cyl
Little 355
My rebuilt L48 . Motor was a total rebuild with .030 overbore . stock crank and rods with new pistons . AFR 195 heads , Comp HR 288 cam , Vic jr intake and Quick fuel 750 carb . Distributor has been replaced and fuel pump has been upgraded . Long tube headers and full true duel exhaust .
Car is a 75 with rebuilt trans , spicer u joints , new 3.55 rear diff . brakes and suspension also all upgraded .
Nice little combo best time 13.1 at 105 mph . Hoping to see times in the 12's this year
ajrothm (04-10-2018)
Received 2,878 Likes
Does this count?
79 coupe. 350 goodwrench crate, 416 heads with 1.94 valves and a lunati 280/290
427 CID. Dart SHP block. Scat forged crank & H-beam rods. 10.5:1 AFR 220 heads. Howards HR cam (233/241 .530/.545) Hooker Super Comp & dual exhaust. Edelbrock Air Gap & Holley 770. Backed up with a TKO-600.
I really need to get some more photos now that its running.
Dart shp 400 with forged callies crank and rods. Pro-filer 210 heads along with .600 lift hydraulic roller 243 intake 249 exhaust duration. Fully ported Victor jr intake topped with quick fuel 950 with annular boosters.
1 7/8 primary 321 stainless headers and side pipes with 3 inch mufflers.
OEM L-82 block, L-82 Rods, L-82 Crank, JE Forged Racing pistons/rings, Howards Roller cam (.525/.525 lift, Duration 219/225, LSA 110), .030 bore, new oil pump, new Fuel pump, New Harmonic Balancer, AFR 180 64 CC aluminum Heads, .015 head gasket, Total compression 10.2:1, Ported L-82 aluminum Intake, Holley 4175, 1 7/8 Long Tube header, etc.
Goes like stink...................And looks like an L-82...................but a 355 with about 150 more HP than non emissions mildly stock L-82!
My original '70 L46 350 block, bored .030" over, stock forged crank and pink rods, polished and resized, Dart SHP 180 aluminum heads, Weiand Street Warrior dual plane, sealed power hyper pistons, ARP fasteners, Howards retro roller, Scorpion rockers, roller chain, billet timing cover and fabricated valve covers. High-torque mini starter, completely rebuilt and re-curved original points distributor, rebuilt and tuned original Quadrajet carb and Doug's 1-5/8 long tubes with 2-1/2" duals, H-pipe and Flowmaster 40's.
I wanted an ultra-reliable driver with good street manners. 9.8 compression and it's all done at 5800 rpm. It dynoed at 392hp and 413 lb.ft and i am running a wide ratio Muncie with McCleod Super Street Pro clutch. Rebuilt the driveshaft, and just today finished installing 3" half-shafts and Bilstein HD's around the new offset arms and fresh 3.73 HD Posi rear to make it snappier than the 3.36 original. Waiting on my rear spring, then alignment and back on the road soon. Have not run this one down the strip yet.
