C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Fuel cell wiring
Old 04-12-2018, 06:31 PM
MikeSVT04
MikeSVT04's Avatar
Default Fuel cell wiring
I got my NX nitrous system hooked up last year and have been spraying a 75 shot to work out all the kinks. I'm pulling off the rail with a BAP and hotwire kit.
I recently got a nitrous outlet deducaded cell ( the one that goes with the dry sump cars) and want to know the best way to wire it up. I have a window switch that activates at 3k off at 6200.
I have a buddy doing the install, but would like to have an idea on what route to take.
I'm thinking I would just need to hook the cell fuel line to the nitrous fuel solenoid, then tap the cell wiring onto a nitrous power line. Does this seem correct? or to I have to rewire a bunch of stuff.
Thanks in advance, I'm doing my best to understand this wiring stuff.
Mike
Old 04-12-2018, 09:43 PM
Jwwesttx
Jwwesttx's Avatar
no the best way is to wire the fuel cell to your activation switch that way you have constant pressure at the solenoids, so when you flip the switch to activate your nitrrous system your fuel pump will kick on, it has a bypass on it so it will recirculate in itself, then when your window switch activates your solenoids it will allow the fuel to spray aswell.
Old 04-13-2018, 04:20 AM
MikeSVT04
MikeSVT04's Avatar
Ok sweet, that makes sense.
Old 04-24-2018, 10:36 PM
MikeSVT04
MikeSVT04's Avatar
She's wired in. I got this system used and not sure what the port is coming off the guage. Can I just eliminate it and stick the guage directly into the regulator?
Old 04-24-2018, 10:40 PM
Jwwesttx
Jwwesttx's Avatar
yea you dont need that extra port you already have a bypass recirculating the tank.
Old 04-24-2018, 11:03 PM
MikeSVT04
MikeSVT04's Avatar
Can I just take all that extra stuff off the guage and plug the guage directly into the top port of the regulator?
Old 04-24-2018, 11:07 PM
Jwwesttx
Jwwesttx's Avatar
all i see in the pic is that 4an behind the gauge, you can pull that fitting out and plug it all you need is your feed to your solenoid, bypass which you already have, and the 90deg 6an on top of the tank for a vent
Old 04-24-2018, 11:15 PM
MikeSVT04
MikeSVT04's Avatar
Got it. Thanks for the help.
Mike
Old 04-25-2018, 12:17 AM
MikeSVT04
MikeSVT04's Avatar
Should be my last question.
What about the vacuum port on the regulator? Anything need to be connected to that?
Old 04-25-2018, 12:23 AM
Jwwesttx
Jwwesttx's Avatar
that is for boost reference just leave it unplugged!
Old 04-25-2018, 12:34 AM
MikeSVT04
MikeSVT04's Avatar
Copy. Thanks again.
Old 04-25-2018, 12:48 AM
Jwwesttx
Jwwesttx's Avatar
no problem glad to help!
To Fuel cell wiring
Quick Reply: Fuel cell wiring
