[C2] Why was Positraction not an option on Automatic cars???
Old 04-17-2018, 09:59 AM
65silververt
65silververt's Avatar
Default Why was Positraction not an option on Automatic cars???
I'm working on a 66 Coupe with a 327/300hp engine and an automatic.
Someone swapped the original rear end out for a 1967 dated 3.70 Posi-traction unit.
From what I have read in my books, the car should have had a non-positraction 3.36 ratio rear end.
So, my question is, why was positraction not an option on automatic cars in 1966?
Thanks
Old 04-17-2018, 10:38 AM
kenba
Support Corvetteforum!
kenba's Avatar
Location: PHOENIX AZ. WHAT A MAN WON"T SPEND TO GIVE HIS ASS A RIDE
Thanks
I believe you could get a posi. with any transmission.
Old 04-17-2018, 10:44 AM
SWCDuke
SWCDuke's Avatar
Received 1,973 Likes on 1,188 Posts
Please state what "books" you are reading to warn others of this misinformation.
Positraction (RPO G-81) was an unrestricted option with all engine/ transmission/standard axle ratio combinations, and all but one optional axle ratio were ONLY available with Positraction.
The one exception was 250/300 HP engines with either four-speed or Powerglide transmissions from '63-'65. The standard axle was 3.36, open, for all transmissions and Positraction was optional. You could also order a 3.08, either open (RPO G-91, about two bucks) or Positraction, but only with a four-speed or Powerglide, not the base three-speed manual.
Fewer than 4500 were sold over the those three model years, which is probably why it disappeared after '65, and I suspect some were ordered erroneously because it's real easy to mix up G81 and G91.
I think the reason this option even existed back in the day is that some "safety experts" thought Positraction was "dangerous" because on a slippery surface like snow or ice when both rear tires broke loose the rear could go sideways. True, but if you know what you're doing a Positraction axle will get you out of a slippery situation while the open diff axle will just spin one rear tire in vane and be hopelessly stuck.
Duke
65silververt (04-17-2018)
Old 04-17-2018, 10:54 AM
AZDoug
AZDoug's Avatar
Received 1,478 Likes on 905 Posts
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
I think the only axle ratio you COULDN'T get posi on was the 3.55 in the C1 cars.
Doug
Old 04-17-2018, 11:09 AM
DZAUTO
DZAUTO's Avatar
Received 3,766 Likes on 1,669 Posts
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
If you bring your car to my house (or just bring the rearend), you can have posi with ANYTHING!
Old 04-17-2018, 11:39 AM
emccomas
emccomas's Avatar
Received 1,283 Likes on 732 Posts
Doug
That doesn't sound right. I have a 1957 passenger car rear chunk with a 3.55 posi in it.
Old 04-17-2018, 11:49 AM
AZDoug
AZDoug's Avatar
The carrier the 3.55 gear set came in (at least 1959 and later) won't accept a posi case unless you grind some of an internal support web away. I would suggest you have a carrier originally for a different ratio and someone put 3.55 gears in, if that is what you in fact, have. Or someone removed part of the web, like I did, so as to fit a posi case.
The 3.55 was only available with a PG, and non-posi in later C1s. i cannot say for sure about earlier ones.
Doug
Old 04-17-2018, 12:24 PM
65silververt
Thanks for clearing that up! I appreciate the replies!
Old 04-17-2018, 02:02 PM
62corvette
62corvette's Avatar
AZDoug,
You are usually right on. However, 62’s had 3.55 with posi. CC was the code with standard brakes, CL with metallic brakes. That wasn’t just on paper-I have an original CC here in the car.
Don’t know how to make that fit with what you said regarding the inner web—this is the original 3789812 case.
Old 04-17-2018, 02:08 PM
midyear
midyear's Avatar
if, for originality's sake, you need a 3.36 non posi, I have one dated 66 or 67 in my assorted rear ends, free if you want to pick it up.
dennis
The following 2 users liked this post by midyear:
65silververt (04-17-2018), William Buckley (04-18-2018)
Old 04-17-2018, 02:54 PM
65vette396
65vette396's Avatar
My 67 has a 3:36 non-posi with base 300 hp and ac. Posi was an option but I guess most people ordering didn't think an auto needed posi as the performance wasn't there. Other than leaving 2 black marks on the pavement, a posi was only good if you got stuck and needed both wheels pulling to get you out of the mud.
Old 04-17-2018, 04:48 PM
AZDoug
AZDoug's Avatar
Originally Posted by 62corvette
AZDoug,
Must have been a '62 only option, probably to account for the larger motor.
The web thing is covered here:
http://www.dallasclassicchevy.com/im...0TO%20POSI.pdf
Doug
Old 04-18-2018, 11:10 AM
emccomas
emccomas's Avatar
As best I can tell, 3.55 posi was available in passenger cars but not Corvettes until 1962.
Always learning something on this forum.
Old 04-18-2018, 12:38 PM
62corvette
62corvette's Avatar
Doug
Doug,
I read that all the way through. I knew about that web—but there was nothing about 3.55 posi at all. Only about changing from non-posi case to house a retrofit posi. Nothing germane to 3.55 ring needing that web cut down. What did I miss?
Old 04-18-2018, 03:58 PM
AZDoug
AZDoug's Avatar
Doug,
Up until 1962, all 3.55 were open diff, you had to cut the web if you wanted to use install a posi case inside the open diff carrier the 3.55 gear set came in (from the factory). It seem pretty clear from my other posts, except for the 1962 thing.
Doug
Old 04-18-2018, 06:14 PM
emccomas
emccomas's Avatar
Doug
Can you tell us what rear end code AK or BK for 1957 to 1961 represents?
Old 04-18-2018, 07:25 PM
65vette396
65vette396's Avatar
My books don't show the AK code being used until the 65 MY for 3:36 non-posi with manual or PG trans.. The AK continued until MY 69. I didn't see a BK referenced in the NCRS Specification Guide of numbers.
To Why was Positraction not an option on Automatic cars???
Old 04-18-2018, 07:33 PM
William Buckley
William Buckley's Avatar
2017 C2 of Year Finalist
2016 C2 of Year Finalist
Thanks
Chris,
The owner's manual in the glove compartment states that positraction is available with the automatic transmission.
Old 04-19-2018, 05:59 AM
emccomas
emccomas's Avatar
The AK and BK codes are listed in Chevrolet by the Numbers for passenger cars from 1957 to 1961 as 3.55 posi.
Old 05-06-2018, 06:51 PM
CorvetteMikeB
CorvetteMikeB's Avatar
Doug
I am getting my 3.36 rear differential re-built. Is there any reason to make it a positive traction? Or just have it rebuilt w/o positive traction....
Quick Reply: [C2] Why was Positraction not an option on Automatic cars???
