Sponsored by: GEM Motorsports
Brisk RR14S vs NGK LTR7IX-11
Old 04-19-2018, 09:30 AM
avtarv
avtarv's Avatar
Default Brisk RR14S vs NGK LTR7IX-11
Hello, first of all sorry for all the noob questions. I have a 19 Z06 on order and the following parts on order. IW 18% overdrive crank, Halltech, Borla off-road X pipe, 160 stat, Fastproms heat exchanger tank.
I am also looking into colder plugs-are the Brisk RR14S any better than the NGK LTR7IX-11.
If a copper plug was made I would honestly be using that then the above-nothing like reading plugs to know what your tune up is like.
Thanks!
Old 04-19-2018, 10:25 AM
JHEBERT
JHEBERT's Avatar
I don’t think you’ll need to use the brisk, but set your gap around .028 on the ngk and your good to over 850rw. The brisk is used on much higher builds and seem to get the job done when the ngk can’t. I myself have used the brisk on high compression/heavy nitrous engines spinning 7400rpm, the brisk kept the chamber lit on the top end when the ngk would not (slight mis-fires). At you levels, I think the ngk are fine and that’s the plug in my car now, 769/791 at the tire.
John
Old 04-19-2018, 10:32 AM
avtarv
avtarv's Avatar
John
Thanks John!
Awesome numbers btw-care to share the mods?
Old 04-19-2018, 10:41 AM
JHEBERT
JHEBERT's Avatar
Callaway 757 a8, ported 2.3 blower with 103mm tbody, 10-rib 9.5 lower/2.625 lower, hand ported heads, my spec cam (22x/24x 116+5), MMS wild catch can, 1-7/8 ARH LT cattless with stock mufflers, 93 octane with a sneeze of meth.
Happening this month:
2.41 axle being swapped for my 4-pinion 2.73 along with RPM stub shafts and DSS axles, and Carlyle 15” drag spindle conversion, 15” weld single beadlocks and M/T stickies. I make 740ftlbs at 2400rpm, 1.32 or better 60fts are coming. I have been 10.20 at 142 on a 19” nitto nto5 with 5k street miles on those tires. That was a fun experience
John
Old 04-19-2018, 11:05 AM
avtarv
avtarv's Avatar
John
AWESOME!!!!! tell me more about the 4 pinion 2.73? Any issues shifting with that gear? I'm dreading sending in the TCM to get unlocked. Do you think its worth porting the blower or just throw on a 2300 Heartbeat?
Your car must sound sick with the cam.
Old 04-19-2018, 12:46 PM
JHEBERT
JHEBERT's Avatar
2.73 not in the car yet, it’s on my bench. I have a thread on it in the c7 tech section. I would do the 2.3 all day long over the 1.7, but that 2.650 Eaton that’s on the ZR1 will be available soon, so there’s that
Old 04-19-2018, 01:33 PM
3 Z06ZR1
3 Z06ZR1's Avatar
Thanks!
I would say with those mods the stock issue A/c plugs would be fine! The worry is if you can get t tuned. 2019? Not sure if is locked like the ZR1.
I would wait and find out before I bought the pulley.
Old 04-19-2018, 03:26 PM
JHEBERT
JHEBERT's Avatar
He will be able to tune the 19, but not the e99 on the ZR1/lt5
John
Old 04-19-2018, 07:54 PM
GeorgeR_Zed06
GeorgeR_Zed06's Avatar
I had the Brisk on my Z51 and wasn't impressed. My NGK plugs just came in as they are going in my Z06 when I install my long tubes next week...
Old 04-20-2018, 07:29 AM
avtarv
avtarv's Avatar
Thanks for the feedback George!
Old 04-20-2018, 05:19 PM
Lasco001
Lasco001's Avatar
Default Brisk
I had tested the Brisk 12 and 14 in my 800HP vehicle
I have everything expanded again, I had only problems
Am currently testing again with original on, car runs perfect again
Old 04-20-2018, 07:41 PM
3 Z06ZR1
3 Z06ZR1's Avatar
Stock A/C for me too with my 2300! Nice plug!
Old 04-20-2018, 09:59 PM
HNK
HNK's Avatar
What problems did you have??
Old 04-21-2018, 01:37 AM
Lasco001
Lasco001's Avatar
With the 12
Engine stutters strongly at idle
With the 14
Engine stutters strongly from 5500RPM
Old 04-21-2018, 09:15 AM
JHEBERT
JHEBERT's Avatar
The 12s are prob too cold and started to foul, what gap did you have on the 14’s? Keep it tight people...
Old 08-03-2019, 12:35 AM
Prop Job
Prop Job's Avatar
Bringing this one back from the dead. I just installed the NGK's on mine, 2300 with supporting mods (16 psi, 1.6 g/cyl). I've seen the recommended gap mentioned anywhere from .028-.038, I gapped mine at .032. Now I'm having a bit of an intermittent misfire at idle and light throttle, haven't done moderate or WOT with them yet. I'm logging misfire on every cylinder so I'm thinking it's got to be a gap issue. I'd like to avoid correcting in the wrong direction and having to go back in there twice, it's quite the pain in the *** as I'm sure you guys are all aware. Which direction should I try first? Any other suggestions?
Alex
Old 08-03-2019, 03:31 AM
Corvette4ever
Corvette4ever's Avatar
What was the misfire count in the log? I would check plug wires first, swap them with other cylinders
To Brisk RR14S vs NGK LTR7IX-11
Old 08-03-2019, 06:25 AM
Prop Job
Prop Job's Avatar
I can't see swapping plug wires around doing much for trouble shooting with it being on every cylinder. Are you suggesting swapping them all with something like the MSD 33823 wires?
I think I'll pull two plugs and regap them to .028 and .038 and see which one it goes away on before I dive into all 8.
Here's the count from a 13 min log.
Old 08-03-2019, 02:42 PM
Prop Job
Prop Job's Avatar
Still misfiring on every cylinder. This is why I hate fixing things that aren't broken.
Old 08-04-2019, 04:13 AM
Corvette4ever
How are your O2 voltage readings? do they fluctuate along with the misfire?
Last year I had a WOT misfire issue on cylinder 7 (misfire count=16). O2 voltage reading on that bank was erratic as you can see below. Light throttle showed no misfire!
Found that my NGK LTR7IX-11plug on cylinder 7 was broken. Switched to Brisk RR12S & never had a problem since then. Both plugs were gapped at 0.028
Quick Reply: Brisk RR14S vs NGK LTR7IX-11
