[C2] Oil pressure gauge
Oil pressure gauge
1967 convertible, L79 motor, when I start the car the oil gauge reads just above the 30 at idle, when I give it gas it goes up between the 30 and 60,
But does not peg the gauge at 60. The engine does not burn oil or leak oil, is the gauge just being a 51 year old gauge or should I be concerned. Ian
Sounds like normal oil pressure to me. It won't peg at 60 unless the engine is stone cold. If you replace anything, I would consider your 50+ year old oil pump, but with 30-60 psi of pressure you have nothing to worry about on a small block. Bill
Received 6,938 Likes
2015 C2 of Year Finalist
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
An L-79 should have an 80lb gauge. Mine had an incorrect 60 lb when I got it and it would peg when cold.
My 1967 327/350 HP car is one of those with the 60 psi gage...........VIN #14845.
Larry
gjhinc (05-30-2020)
Received 1,974 Likes
GM's spec for all year L-79 oil pressure is the same as the base engine, 40-45 psi at 2000 with the engine fully warmed up. Look at the AMA specs. GM does not specify idle oil pressure, and it is highly dependent on idle speed, so a base engine at 500 will show less than a L-79 at 750.
As previously stated you have an incorrect pressure relief spring, and maybe an incorrect (high volume) rather than standard volume oil pump, which are common "engine builder" mistakes.
Duke
Duke
You guys are right. Don't know where I got the idea that a L-79 should have the 80lb.
I apologize for my error.
