Transmission Fluid (gear oil) replacement cost
St. Jude Donor '17, '19
Hey guys,
I have the car (1980) in the shop to do some things I don't have the tools for, like repacking the front bearings.
While it is in there, I thought I would have the transmission oil changed as discussed in another thread. The guy wants to charge me $50 for the oil and labor. Is that good? Most of my standard oil changes for my mustang/corvette are around $20-25 so I was surprise to see it be double.
I would do this on my own, but now I don't have to worry about the mess or disposal.
Thanks.
Thanks.
Hey guys,
Thanks.
Thanks.
Received 1,468 Likes
Cruise-In II Veteran
Is it worth $50 to you to have the shop do it?
I easily spent twice that on fluid, and the tools to do it correctly (manual). But now I can do it a few more times for free.
I hate the smell, too, but the full synthetic isn't as bad.
A tool for repacking the front bearings??????????
Who told you there was a tool to repack the front bearings especially the inner one???
A quick summary is, you remove the wheel, remove the brake caliper, remove the rotor, clean the bearings of any old grease, slap some grease in your hand and work the grease into the bearing. Reassemble everything.
It takes a crescent wrench and 2 quarts of oil (dino gear oil is $7/qt. and syn gear oil is $13/qt.). How did you spend $50??
I bought a lifetime supply of Redline, $60. A pump attachment, $10, and a sucky thing for the diff, and a hedge against a stuck plug (also works for the Power steering reservoir), $20-. Add some paper towels and tax and you are at $100-.
I also have a Lisle 34550 Handy Packer tool to the other comment. Works great to displace the old grease. Push down ustill the new grease flows.
Manual? Does it have a drain?
$50 is not out of line in California. In fact that would be cheap.
My Muncie didn't have a drain so it's a suck and fill. Takes more time.
Packing by hand is easy but the tool makes it super simple. I also like the took to force all the old grease out for a repack.
Hey guys,
Thanks.
Thanks.
Your friend was referring to the rear bearings. The front are the same as millions of Chevrolets, Pontiacs, etc., no special tool or press needed. It might be advantageous based on this thread and others you have posted to invest in a copy of the factory shop manual and read through it. It is the best source in the world next to this forum on learning about your car.
