Radiator shroud on a '77
Is it possible to remove/replace the radiator shroud on a '77 with the radiator in place? I am in a reassembly phase and would like to install it near the end of the project in case I need future access. The main hang up is the left upper control arm. I am thinking of cutting the shroud in half or cutting out a big piece and then putting it back together in situ.
It's been a while but I took the shroud out when I replaced the radiator on my '77 without dealing with either control arm. I took the shroud out first, then the radiator, so it can be taken out in one piece without removing the radiator. I believe all I did was remove the fan and fan clutch first. I replaced the water pump at the same time but I believe that was incidental to the shroud removal.
Update: In reading through the subsequent posts it appears that my removing the water pump wasn't incidental and was the key to my ability to remove the shroud without removing the radiator.
Received 2,126 Likes
I am trying to remember if I had the Rad out when I removed the shroud. I believe I did.
Of course the Waterpump has to go.
I know several have cut on the shroud to get it out. I could see some small cuts on my '77 shroud from somebody. Minor stuff.
In my opinion, if you cut it in half and then brace it back together you are not only asking for future trouble issues but also the bubba factor comes in to play. I vote no on the saw.
I'm not sure how similar the '77 and the '79 are, but I know on my '79 I cannot get the shroud out with the rad in place. I remove the rad prior to removing the shroud, and then the reverse on reassembly. It might be possible with the water pump removed, but I haven't tried that.
On my 77 had to remove radiator first then shroud. I didn’t have water pump off, just fan and clutch, so maybe it would help.I would vote against cutting the shroud, someone had notched out mine and I didn’t like it so bought another one. Check out the cost for one and you’ll notice most places are quite proud of them.
Exactly. This (shroud) isn't some easily replaceable part from your local NAPA or Ace Hrdwr store. This is a antique part that is hard to find and expensive. Just don't seem right to hack on it.
But thanks for the advice and your concerns are duly noted (bubba factor...ouch). One option is to put it in place and install the radiator, if I leave the shroud loose while I am putting things back together it can be shifted around. Maybe that will give me enough space or room to do whatever it is that I need to do in the area.
Jim
On another note. If you have a buddy handy, have em help you remove the hood. Things get easier with that off to the side. Just remember to scribe a line around the hinges for reference / alignment.
Hood's been off for a long time. I replaced the right front fender due to multiple poor repairs courtesy of the previous owner. Took this photo a couple of months ago, I am hoping to get it back on the road by the end of summer. Needs a whole new interior too.
Looks good. You poor Cali-forn-I-A guys have to run those smog air pumps. Bluck.
Bad design, they should have made it so that it could r/r without pulling either the radiator or water pump but then again all the part and assembly drawings were done by hand. They didn't have SolidWorks like we do now...
Today I put the unmolested shroud in its place, installed the Vintage air condenser onto the radiator support and then the radiator. The shroud is loose and it looks like there is enough room to install the transmission cooling lines (Bowtie overdrive 700R4), the VA drier and the condenser connections. Wiring and vacuum lines should be no problem so it looks like this will all work, a bit awkward but it will work.
The other thing that happened today is as I was driving over to the Ace Hardware store to get some fasteners my buddy down the street was working on his C5. I stopped to chat and he said he has a track day scheduled Tuesday at Laguna Seca and asked me if I wanted to tag along. Didn't have to think too much about that...
