Has Anyone Used The Diablo Sport Tuner ! What We're The Results
Location: S/W ,Fla-Ohio State Football isn't a matter of life or death,Its Much More serious than that
Received 1,142 Likes
For an LS3 Manual ????
Is it worth the money ??
https://www.diablosport.com/intune-i...rmance-tuning/
I have the older Diablo Sport Predator. Definitely has a better throttle response, and it disables the CAGS. I bought a used one, so it was worth what I paid.
Received 2,093 Likes
About now is when Cow starts to bombard you with his pitch....
At $400 I would think you could get an hptuners tune which would be custom to your car. I would probably look into that personally. But a lot of that would depend on where you're located and where the tuner is
If you've got any mods, a custom dyno tune will be best.
My son uses one for his 392 charger with custom tuning. Seems to work good. Data logs, easy to use. Hasn’t been on the dyno but other vehicles picked up 20-30hp//tq at the wheels.
Received 4,712 Likes
a handheld is nice if you still have a warranty on the car. Need service work done? flash the stock tune back in, get the work done, then put the good tune back in.
Used intune i3 & Diablew, have to say the canned 93 tune woke the car up impressively, & after Lew was more responsive on WOT. Haven't dyno'd or tracked it, but SOP (seat of pants, you can use that now!) feel is noticeable. And think of cost... i3 with Diablew runs you ~$550, & can easily get a dyno/custom tune for maybe about the same or a little less, but as others have said, with Diablo you can easily go back & forth between custom & stock, so for the convenience that may be the deciding factor...
chrisharek (12-05-2019)
