Turn Signals?
Turn Signals?
So I've been gone for 3 months and my Hemi Vette has been sitting in the garage with the battery disconnected and a car cover.
When I get home I put the charger on and the next day she starts right up, but no turn signals!!!! So today I check all the wiring under the dash, check all the fuses, wiggle all the wires under the dash, look for any lose ground, but no luck.
I check the Corvette 63/65 manual but nothing there that helps. Can't find the turn signal actuator, the one you hear clicking. No lights on the dash, but all the lights work, brake and running lights.
I'll foose with it again tomorrow but kind of at a lose for whats going on. The turn signal actuator i'm familiar with is a round aluminum one but can't find anything like that in the car?????????
The actuator should be attached to a clip on the console's left sidepanel. Near your right knee as you're sitting in the car. You might have to remove that sidepanel to find it -- someone may have stuck it back there rather than where it's supposed to be.
Flasher
The turn signal flasher is located on the left console side cover, above your right ankle when your foot is on the gas pedal. It should be mounted in a clip. If it's not in the clip, then it is probably just hanging down out of the dash just to the left of the console side cover.
RON
RON
Ok I did see a little clear plastic thing there. I could see the copper coils inside. Never seen one like that. I'll pull it and check and or replace it.
Thanks all
KO
Thanks all
KO
Just a thought.
Dave Z
Thanks guys. Never saw a flasher like that before. Ran down to Napa and got a replacement and all's cool now. Well it was only 50 years old.
If it was clear, it was only a few years old. The fifty year old ones were silver with a bi-metallic strip inside and you couldn't see inside them. Great that it fixed your problem, you may have LED's as mentioned.
