Eco Mode Question
Select Eco mode for improved
fuel economy. This will result in
better Active Fuel Management
(AFM) operation. See Active
Fuel Management® on
page 9-25
Active Fuel Management®
This system allows the engine to
operate on either all or half of its
cylinders, depending on the driving
conditions. With a manual
transmission, the system is only
active in Eco mode. With an
automatic transmission, the system
is available in all modes, but is more
aggressive in Eco mode. See Driver
Mode Control on page 9-39.
When less power is required, such
as cruising at a constant vehicle
speed, the system will operate in
the half cylinder mode, allowing the
vehicle to achieve better fuel
economy. When greater power
demands are required, such as
accelerating from a stop, passing,
or merging onto a freeway, the
system will maintain full-cylinder
operation.
Fuel Management® on
page 9-25
operation.
DSC Controller Affect on Warrantee
Get a DSC Sport controller. www.dscsport.com. Rides like a luxury car in eco or wet mode now. A lot better in all the modes, in town I use the Wet mode, best ride and steering.
Thanks!
Montana Bob
Why do you care? If you are going to the dealer for service and are worried just swap the OEM controller back in. It's a 10 minute job after you have done it once and know what to do.
Thanks for the prompt response.
I care, because, if I am not mistaken, any changes or modifications are retained in memory, even if the non-stock component is replaced with a stock unit. Even if that is not true, I'd have to install the controller with wing nuts or Dzus fasteners, as I'd have to swap it out every time the car went into dealer for service.
Thanks again.
Montana Bob
Are you saying I can get a better luxury ride in Tour with a DSC? How much better?
RonSC,
Montana Bob
Montana Bob
Last edited by Steve Garrett; 04-21-2018 at 01:55 PM. Reason: Merged Posts-please use the Multi-Quote button (the middle icon) in the lower right hand corner of each post to make your reply look like this!
My thanks for your response.
I bought my car used in February. Upon inspecting it prior to purchasing it, I discovered the right rear shock weaping and the left rear leaking. The dealer replaced the LR, under warrantee, but said that the GM rep would not authorize replacement of the RR as it was not leaking yet. (The $64 question, of course, is at what point does a "weap" become a "leak".)
The bottom line is that I am extremely careful of performing any changes which void either the GM or extended warrantees. My experience over the years has shown me that manufacturers will look for any excuse not to honor their warrantees. I've got lots of "scars" from previous battles!
Montana Bob
RonSC,
Thanks again.
Montana Bob
Thanks again.
Montana Bob
As to swapping the unit it is not really held in by anything except the lock type connector. It's just a matter of loosening a few push pins in the left front fender liner and then reaching in and plugging the current module and replacing it with the other one. If the DSC unit causes a problem, just put the OEM unit back in.
BTW if you have a new model the OEM controller may be fine for your purposes. There is an update for older models which apparently softens the shock settings in the tour and wet modes.
Is there a thread that talks about that update in particular? I'm not sure how to know which is which.
Thanks!
Dave
Ron is absolutely correct. Here is a link to the most comprehensive of the threads addressing the Magride Upgrade issue:
https://www.corvetteforum.com/forums...y-car-yet.html
Jeff V. did an incredible job of helping everyone on the issue.
Montana Bob
Montana Bob
Wait, I thought I asked this months ago, and it was no softer than factory Tour, or so I was told.
I would imagine worst case you're voiding your suspension warranty, but having never had a suspension warranty claim in my life that I can think of, not sure how much that is actually giving up!
Received 8,918 Likes
Bill
