How much clearance do I need spoke to caliper?
Trying some ccw I have on the c6z. The rear spoke is just kissing the caliper. Would a 1/4" spacer be enough? These are 18x12 rears. I would get a little longer stud so I can get at least 8 turns.
1"4 would also let me clear the tub a little more, now it's maybe 1/8 to 1/4" clear on the tub (hard to measure it).
Fender looks to be ok. As is the control arms etc.
Also the tires are 335x30x18 so I may go to 345x30x18 (as far as the tub & fender.) But I don't want to spacer out more than needed because of the fender.
Really? Eight hundreth's? Whoa, I would never have figured that close. So if I am right touching, I only need a tiny spacer, maybe 1/8 inch if they come that thin. Might not need the extended studs as I get about 9 turns stock.
Anyone have a source for thin spacers?
Take a look at the note near the bottom of this page:
http://www.wilwood.com/Images/BrakeK...229_wcd-lg.jpg
Get some thin stock from McMaster and drill some holes!
Because a wheel shouldn't be deforming and caliper/wheel when bolted up are static; .00000000000000000001" would even be enough. I've seen people grind calipers to fit wheels and only take away just enough to allow wheel to spin.
http://www.motorsport-tech.com/wheel...ers_pop_car_d1
froggy47 (04-21-2018)
I had this same issue a while back.
I spoke with AP and a Brembo rep. Each recommened a minimum 2mm clearance with a good forged wheel.
I have been running a 3mm spacers without issue.
Destroyed big brake kits and wheels..... $11,000.00
Real world experience..... Priceless....
I’ll agree being on safe side is wise, always. And good points that it’s not exactly static. But sounds like y’all are blowing out wheel bearings, they do not have the play that is being suggested. Obviously my .0000000000001 was a wild exaggeration. I’ll be more careful in wording.
But ya never know.
Wheels flex too.... there absolutely needs to be a gap to allow for movement of the wheel. A few mm sounds good unless there is excessive play in the hubs.
BrianCunningham (04-24-2018)
I would say that it depends on how FLEXIBLE your wheel is! I run Stoptech BBK (front and rear) and run a (soft) matchBOOK of space between caliper and wheel with no problems (on race tires).
Received 8,918 Likes
Bill
froggy47 (04-26-2018)
