Aux port on base c6 with nav?
Apologies, I know this has been asked a million times, I have spent a lot of time searching to find info on here about it. I found aux cord options with base stereo but I have a nav unit. I haven't been able to find anything. Can someone point me in the right direction or thread so I can read about how I can hook my phone up to my girl so I can listen to my music? Or where the aux cord port is..... I have a feeling this is going to be an "oh duh" moment.
thank you,
Hoss
thank you,
Hoss
The USB/AUX port was only available on the 2011+ models with nav. If you have a 2011+ C6, it will be present inside the center console lid near the back.
I swapped a 2011+ Nav in my 2008 with the center console and cables to support it. That is something you could do.
There are also other cheaper/easier methods, but they won't be as seamless. Check this site for more info:
http://www.kawal.net/vettemods.htm
PoppaHoss (04-20-2018)
Contact forum vendor Ray Kawal. He has a harness that is a simple plug in. Works seamlessly and install is simple. I have had mine for over four years and it works perfectly every time. Around $100.00 if I recall
Race Car Tech
I added the aux 3 harness from Ray Kawal to my 2006 Nav unit.
It's plug and play. The connectors plug in at the back of the Nav/radio unit.
I installed the aux input in the console area.
I did this on my '06 and GS.....
https://www.corvetteforum.com/forums...s-with-xm.html
Gotta-Qik-C7 (04-23-2018)
I personally installed the Isimple ISGM655 on my 06 with the nav radio. IT gives you an usb port as well as bluetooth connectivity. Works really good and does not stop the usage of the cars other features. IT did require removing the console and the radio so you can plug it into the back of the radio but the directions are in video on youtube. If you do do it be sure to message me for one specific direction that is not listed anywhere.
Creedence85 (07-05-2018)
+1 on the Ray Kawal!
