Buying a used performer 2101 intake
Hey everyone.
Next week I will visit some guy that sells an edelbrock performer 2101 intake.
He says it is almost new, and on the photo's it also looks that way.
Gaskets and screws are also included with the original box and packaging.
What are important things to check on a 'used' performer 2101 intake?
Received 2,112 Likes
There are dozens on EBay anyway, thats for sure. Its not likely the used one is warped but check all the bolt holes and water hose fitting bosses for hairline cracks. Because they are NPT, its possible to crack a boss from over-tighting a plug or fitting.
Some used ones on EBay come with carb studs, dizzy clamp, all bolts, heater hose fittings and Vac port hardware. Thats all a plus.
Main thing is its not stained with grease / oil / gas on the porous surface.
to get equal fuel distribution you will need a hot oil shield because 4 of the intake runners are exposed to the hot oil and 4 are not.
The following 2 users liked this post by PAmotorman:
cardo0 (04-21-2018),
Street Rat (04-22-2018)
Thats clever, but I would think that plate would retain the heat instead of repel.
(Like a little toaster oven)
I will tell the Edelbrock engineers too.
But thats what the Air Gap is all about.
One thing that drives me crazy on used intakes is when someone paints them to "clean" them up, they often just spray the whole thing (without masking), paint in the plenums, water housing, etc, because they fail to mask them off.
Not to mention, paint on every mating/gasket surface, which is begging for trouble. If you see painted mating surfaces, run away, LOL!
Also check the water passage for rot. They get put on boats and run with raw river water, or worse yet, salt water.
Thats two different designs, really. One keeps the hot oil away from the manifold. The other design elevates the carb away from the hot manifold.
Like I said, I like the concept of the steel pan, but I question if that pan just traps heat inside there like a hot chamber with no air circulation.
The Air Gap gets plenty of air circulation. Hence the name AIR----
I like the snap in oil shield that fits down by the lifters. Metal spring ends tuck under the heads to retain it. Keeps lifters down in the bores if you loose a rocker arm or pushrod. Keeps oil splash off the intake gasket seal too. Small vacuum leak there can be a real pain.
Is there a small block version? I have only seen them on big blocks.
You still may benefit from adding the aftermarket shield in the bottom of the valley because it keeps all of oil splash out of the area and it holds lifters in place in the event of a valve train part failure. I installed a crate engine many years ago that was fouling plugs a bit. I found a leaky intake gasket was sucking in oil. I used the baffle because I hate oil getting past the intake gasket as it can allow excess oil consumption after an intake swap. Not as uncommon as you might believe.
Ok, I bought the performer 2101 intake. It was really new!
I also got a set of goskets (also edelbrock), water neck + bolts, and 12 SS bolts.
The only things I still need now is 4 studs (SS) and a good gasket for the carbu.
Are there other parts that I will need?
