Anyone use high octane fuel in a stock LT4?
Like the title says, just wondering if anyone has used high octane / racing fuel with a rating of 104 or higher in a stock LT4 engine?
Are there any adverse effects that could occur using such fuel with a stock set up, or will it run like a champ?
I was thinking of getting 5 gallons to really clean out the fuel system since we have a local track that sells race fuel of varying grades.
I just know lots of you track your cars and thought someone has done this and might chime in, as I surely don't want to cause a problem by doing this without some homework.
Thanks!
Thanks!
Waste of money.
Match fuel to engine needs.
You can put jet fuel in a drag car and it won't go faster or cleaner.
You can put 110+octane in a factory car and it is the same effect. Speaking from experience I did this as a kid watching some guy with a "cool" 383 that would mix. It was was dumb, and I was more dumb to follow. If you have like 12+ compression yes, it would be needed.
My current build makes literally 4-5 times as much power as my car back then and I can still run on 91-93 pump gas.
I think the newer fuels have "cleaning gents" more octane does not clean a fuel system.
Cleaner or buying new injectors, changing fuel filter, and fuel pump will make for a a clean out.
Your car can run on 87-93 octane and it won't help or hurt it.
SR71! (04-21-2018)
Thanks!
Thanks!
If you are having dirty injectors, send them for cleaning. Results will tell you how often you may want to clean them. So if you are comfortable with say a 5% loss every 5 years, clean them then. Race fuel probably won't clean much.
If you want to do your homework, get a scanner that can datalog. See how much knock you get doing say 5 WOT runs with premium gas, run the car to empty, dump say 5 gallons of race gas and do another 5 WOT runs in similar conditions. Compare and contrast.
SR71! (04-22-2018)
Like Pologreen1 already made clear, you don't want to do that.
I would add that the c4 era cars test the knock sensor by advancing the timing until a knock occurs, a few seconds after startup. In the event the ecm/pcm cannot make the car knock, it may stop advancing the timing, or set a knock sensor code, or both.
I never personally verified this, but it is what was taught in fuel injection training by GM instructors, during that era.
SR71! (04-22-2018)
