Starter Spins, does not engage
Old 04-21-2018, 08:43 PM
M-Racer
1st Gear
M-Racer's Avatar
Default Starter Spins, does not engage
1990 Base Corvette, new starter.
Starter spins, but does not engage.
Nippondenso Starter
Old 04-21-2018, 11:37 PM
aklim
aklim's Avatar
Received 2,230 Likes on 1,942 Posts
Nippondenso Starter
Possibly the armature is bad. Take it to a rebuild shop and see if they can rebuild it economically
Old 04-22-2018, 09:13 AM
arbee
arbee's Avatar
OP notes "new starter". Also, "Starter spins, but does not engage."
It can't spin with a bad armature. Starter drive needs to be checked.
Old 04-23-2018, 02:47 PM
WW7
WW7's Avatar
If it's a new starter take it, or send it, back...Why mess with it.. You do know that you have to shim these starters to make them fit ..right? It's not just bolt them up and go. You have to get a specific distance between the gears teeth to make them work right..If they're not right the gears won't engage....WW
To Starter Spins, does not engage
Quick Reply: Starter Spins, does not engage
