1961 fuel injection question
St. Jude Donor '06-'07-'08 & '12-'13
Went to start my 61 after sitting for about 6 months.
Went through car all fluids etc like i do every year
It will crank and wont fire.
#1 Have plenty of spark at plug wires and coils.
#2 Pulled all plugs and put new ones in them ( ALL DRY) no fuel on them.
#3 Float in fuel unit is not stuck and fuel in the bowl.
#4 Pulled off fuel filter and when i crank lower pump pumps fine.
#5 Pulled off copper fuel injection line ( NO FUEL COMING OUT)
#6 Upper fuel pump to bowl off distributor works fine has pressure.
#7 I have a siphon break solonid in my fuel unit and i do hear it clicking
( engaging when i turn the key so i don't think that is an issue.
Was going to pull the fuel unit off tomorrow and put it on the bench.
Any thoughts would be greatly appreciated.
Thank You
Thank You
Before you do that, pull the small hose that connects the bowl vent to the plenum and squirt a little gas straight into the plenum fitting, reconnect the hose and see if it will fire. After a long nap I always do this on mine and it fires right up without a lot of cranking.
burtonbl103 (04-22-2018)
Received 3,769 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Mistake number one-----------------------DO NOT, DO NOT, DO NOT ALLOW AN FI ENGINE TO SIT FOR AN EXTENDED PERIOD OF TIME!!!!!!
They need to be started and run for a while at fast idle, preferably until the engine is thoroughly warmed up. Do this AT LEAST once a month! Every 2-3wks would be better.
Received 6,524 Likes
C2 of Year Finalist (track prepared) 2019
Before you pull the unit try what Klaus (K2) suggested and verify that the Cranking Signal Valve is operating.
CSVs typically will fail open and in that case the engine will start but it runs excessively rich. However, I have seen a few CSVs fail closed (very rare failure!) and the engine would not fire.
One other rare failure I've seen is an anti-siphon solenoid valve which clicked on command but which wouldn't pass any fuel. I doubt this is your problem, but it's worth mentioning.
Jim
Jim
i know . I know my dad died last year we did all car thkngs togther its been really hard for me to even touch thrm this past year
Received 4,551 Likes
2021 C8 of the Year Finalist Unmodified
2019 C1 of Year Winner (performance mods)
2017 Corvette of the Year Finalist
2016 C2 of Year
2015 C3 of Year Finalist
Bill, we're going to get you back out driving that beautiful fuelie this year. That is exactly what your Dad would want and just what that car needs
The day it was delivered from Nevada a few years ago:
The following 2 users liked this post by capevettes:
burtonbl103 (04-22-2018),
jerry gollnick (04-22-2018)
Received 1,843 Likes
silver837 (04-22-2018)
Never tried it.
Apply a vacuum to the threaded fitting and see if you get air flow into the push-on nipple. If you do, then the CSV isn't stuck closed and it isn't the reason your engine won't start.
Um, new thought..... this is a '61, yes? Has anyone replaced the original piston-type spill valve with the newer (and much better) thumbtack style spill valve?
If you put a shot of fuel in the intake and the engine starts (or starts/dies), you can just zero in on the CSV as a possibility.
I wouldn't put the CSV in any kind of solvent. If you ruin it, you get to pay $100 for another one.
I'm out. Too many cooks spoil the brew, er stew.
Since then, I have done the same to several of these over the years and I've had pretty good success. One is on one of my 63's and it was still working several years later when I last fired the engine about 10 years ago.
Many years ago, I dropped a non working cranking signal valve in lacquer thinner for about 10 minutes. If it didn't work, I didn't have anything to loose so I went ahead with the test. When I removed it, I dried it thoroughly and tried it. It worked!
