WTB: Driver side door glass
Glass
tHANKS
I'm looking for no visible scratches, mine has it pretty bad from the anti rattle pad. I've read 91 and up is different? Is it just the tint and date code stamp or are they physically different? Has anyone mixed a 91 or newer door glass with older side to side? Is it noticeable?
hEY RICH , NOT TRYING TO JIZZ UP THE THREAD , BUT GLASS HAS DIFFEENT THICKNESS, WEIGHT ,TINT ETC. EARLY YEARS ARE THICKER AND HEAVIER. THREE DIFFERENT BRANDS/MANUFACTURER FROM 1984-1996 BLAH BLAH . IT SOUNDS LIKE HE HAS AND WANTS A LOW MILEAGE ORIGINAL GLASS THAT KEEPS HIS CAR ORIGINAL TO HIS BUILD DATE. THERE IS ACTUALLY DATE CODES ON THE GLASS FOR NCRS SPECS. OP GOOD LUCK IN YOUR SEARCH.
RICH, YOUR 96 HAD AN EZ COOL WHICH IS LIGHTER, THINNER AND TINTED DIFFEENTLY , THE 89 YOU REPLACED IT WITH IS TOTALLY DIFFERENT GLASS.
GLADLY POST THE 100 PLUS PEICES OF RIGHTS AND LEFT. HAHA NO THANKS
SPARKY
SPARKY
SPARKY
SPARKY
hey sparky, new information i did not know. maybe i will put the 96 glass back in the 96 and just have to re align the windows. installed new seals and front alignment fitting.
Fauxari08 is correct in everything he's mentioned. What you need to maybe consider is do your left and right 'date codes' match now? If NO then ask him to see if he has a match to your right.
I believe these date codes are correct for the C4.
https://www.corvetteforum.com/forums...post1583238481
