c5 power seat switch
One of the screws, at the lower front side of the bezel, is easily visible. The second screw is hidden by the seat back adjustment lever. The lever is held in place by one of those spring clips, similar to the ones used on older generation window cranks.
The problem is, the slot where you access this retaining clip, is on the underside of the handle. In all honesty, it's easier to access this clip, with the seat out of the car....
cuzzieedward (04-22-2018)
