WTB: Corroded Intake on a 327 - Where to Buy?
As we're going through the engine --next (after the lifters) we've found the intake is thoroughly corroded. I was thinking repair --but dummy me my mechanic friend laughs and says you can't repair it.
Is this something that's standard and I can just look in used parts places online for using simple search terms "327 Intake?" Hope hope.
Well now TY! --Wow. THAT's good to hear. Another gent on here PM me and offered to sell me one that was professionally prepared for $450. which, according to my mechanic friend, said "seemed like a lot." But if it can't be repaired it's always nice to have an option.
Because this car / engine is being totally refurbished and every time I blink the that dang cash register is going ca-ching - ca-ching.. lol. --I need to cut expenses where I can but still keep it a top notch job.
I talked to my mechanic friend and he said he took it to two places and they said no. I was not with him so I don't know why. Could be it's they're just lazy or inept... Who knows. He's going to take it to another place tomorrow.
Received 1,919 Likes
That's a lot of unknowns for a professional car mechanic.
I would be careful on the cha-ching paying a mechanic to run around with an aluminum manifold "try to find a welder" as I would expect a mechanic knowledgable in older cars to know how to get aluminum welded.
However, that doesn't mean that I would weld the manifold either, as the corrosion appears to be galvanic (electrolytic aqueous solution in contact with dissimilar metals - aluminum loses) since the entire area around the coolant passage is possibly very thin.
So what kind of engine and what manifold are we talking about here? A nice original date-coded 461 aluminum manifold goes for in the $400 range. Does your car require one? Low HP Vettes used a cheap cast iron manifold and you can't hardly give those away (I've got one off a '65 I think that I tried to sell for a year with no takers, and at less than $100).
So what kind of engine and what manifold are we talking about here? A nice original date-coded 461 aluminum manifold goes for in the $400 range. Does your car require one? Low HP Vettes used a cheap cast iron manifold and you can't hardly give those away (I've got one off a '66 I think that I tried to sell for a year with no takers, and at less than $100).
Thanks Gents!
When I have a picture of mine I'll post it so we can be sure it's a match.
If it's a match hopefully you can post a picture of yours.
If you buy an aluminum manifold that has not been "professionally prepared", make sure the threads for the fittings, studs and bolts are all good. It's not unusual to find stripped threads on an aluminum manifold.
If I'm not mistaken, an "HF" suffix indicates this engine was a 327/300 hp which likely didn't come from the factory with an aluminum intake.
https://www.ecklerscorvette.com/corv...1963-1972.html
Jerry MacNeish Restoration Services can repair your aluminum manifold. He does beautiful work but it won't be cheap. If you choose to repair it, give him a call and get an estimate.
http://z28camaro.com/restoration-services/
Hi --sure appreciate you taking the time to reply and I learned something! TY. As far as the engine goes what I'm actually dealing with here is a Chevy Small Block #3858174 V8 327 - MFG 1964-67. Engine #FO4I8HF. (not in the original vehicle). Does the one you have for sale seem like it'll fit that engine? I'm having my mechanic take a picture of it to show you. It would be a stroke of sheer luck if yours fit. If it appears to fit can I get a picture?
(Removed)
Here's the thread where I'm trying to sell mine: https://www.corvetteforum.com/forums...-corvette.html
Ah... So you're saying the intake isn't the original (?) I'm thinking it was some real dolts that hack slapped this thing together. I found this one online:Edelbrock Performer Aluminum Intake Manifold, Without EGR Valve 2101 Corvette 1963-1972
Received 1,124 Likes
[/QUOTE]
That manifold appears to accept a QJet.
If you need the front oil fillter I would look for this one if you are going aftermarket.
Joe
https://www.ebay.com/itm/Edelbrock-C...p2047675.l2557
[/QUOTE]
Joe
Hello Sir.. Can you guarantee the threads are good and everything 100%? If so any chance of a picture? I think I'd like to grab it --I PM'd you right after you posted but you disappeared.
TY Sir.
I sent photos to my mechanic.. he'll have the final say... but he probably can't see anything more than I can. Doesn't appear to be any cracks.
If he says yes --I'll PM you my address so we can figure a shipping cost. Sometimes it takes a day for him to get back to me. There's a language barrier so we have to get translators. But he's the best mechanic I've ever seen so it's worth it.
I wonder if finding a gasket is going to require the same hunt...
Also have to add --
WHAT AN AWESOME FORUM - I'm used to Los Angeles --Everybody is out for themselves and has an agenda, even simple 'friendliness' is dependent on "what's in it for me?" I grew up on a farm in upstate NY where we were just naturally friendly and helpful. A lot like this forum --so for that --THANKS GUYS!
Also have to add --
TY Sir.
Also have to add --
Also have to add --
My findings as well, although there are some, very few, that try to sell junk , but they don't last very long, just like a bad virus.
The vast majority here are super helpful, even the few that want to spend every post validating their greatness. But even those are helpful if you can get past the puffery.
