[Z06] I got the itch again, my build 2.0
I think the saying goes you can't leave good enough alone. Well a year after finishing my car I decided I wanted a little more.
I was doing my heads last year when I found some issues with the stock cam and lifters and kinda rushed into putting in a cam. The cam I chose was nearly stock, basically just adding more intake duration (220/232 120+3). Here is the link to my original build
https://www.corvetteforum.com/forums...e-details.html
The car drove perfect and made good power 520 & 510 tq, but after a year of driving the car, and going to some car meets around Houston I realized I should have gone bigger with the cam because I wanted the cam sound and a stronger mid range power band. However, I still did not want to give up any drive ability for a little extra power.
I wanted something that made strong mid range torque, and not something that makes most of it's power at 7k rpms, but more mid range. I spend 99.9% of my time below 6500 rpm so that was my focus with this cam. I always loved the dyno graphs of the torquer 110 but it's a little to rough for me at 12 degrees overlap. The 116 is really not a torquer cam because it closes the intake at 46 (same as stock) where the 110 closes at 40 (to build more dynamic compression and make more torque for those not familiar with valve events). I decided to do a custom spec so I went with a 224/240 115+4 (2 degrees of overlap at .050. IVO 1 BTDC IVC 43 ABDC EVO 1 ATDC EVC 59 BBDC. The actual cam card came back at IVC at 42.6 which I was happy with. I went ahead and added an ATI 10% UD pulley while I was doing the swap.
I took my car back to SeriousHP in Houston for a touch up tune, and as I stated before to anyone in the area these guys are the best shop I have every worked with and I have been to a lot of shops over the years, I highly recommend them!
All in all I was very happy with the results, I was hoping to have a little more peak torque but as you will see on the graph the torque hits 500lbs at 3800 rpm and maintains past 5700. Final numbers were 549rwhp 518rwtq, but most importantly is drives the same as before. Has a nice little lope driving around town, and no bucking or surging. Here is the graph and the final dyno run.
Oh and I forgot to mention the most important thing I checked my mold start 90 guides after 4500 mile with the Yella Terra rockers, and they were rock-solid. Just the tiniest amount of play which is within spec.
Received 1,679 Likes
Very nice... Congrats on new numbers...
Nice curves! I prefer leaving 20 peak whp on the table, picking up 30+ wtq everywhere else and not dealing with the driveability issues when using a smaller cam rather than a high rpm peak power cam. And this is coming from a professional tuner that can handle the big cams.
In many cases, the slightly smaller/torquey cam will actually be faster in the 1/4 mile if that's what your into. It definitely helps out of the corners on the road course as well.
Congrats!
Congrats!
My thoughts exactly! I am not one to do a lot of freeway runs risking tickets, or worse jail time, so mainly my car is just for running around town having fun with it. I drive pretty aggressive so I want that mid range torque, and yet still have perfect manners when driving through parking lots.
I too have been in big cam cars before and I don't care for how the car behaves in everyday street driving. When you look at dyno graph's of bigger cams the suck down low and don't make power until 5k rpm.
Great results. I went through the same delima and unfortunately a few cams before I found what I was looking for. I wanted to be able to cruise in 6th without bucking and I can do that with my current cam as low as 1100 rpms. I still made 564whp and 502wtq. My cam is 236/250 .635/.635 lsa115+4. I had Pat G spec this cam for me based on my goals and how I planned to use my car.
Do do you know what your corrected SAE numbers are?
I never asked if these were the corrected numbers, I know it was about 70 degrees and low humidity when he did the dyno runs. 5% smoothing on the graph.
In regards to your comments on the "big cam" I will have to politely disagree.
Attached is my dyno sheet. Fairly large cam with 27.5 degrees of overlap.
Makes at least 500RWHP by 4300 (earlier than your smaller cam), and makes at least your peak RWHP from 5300 and over 600 still by 7300.
Down low matches or exceeds your HP/TQ by 3000.
I would not say that a large cam with a well thought out combo is soft anywhere.
Congrats on your new combo, like you I went back and changed a few things!!
Great results and glad you got the results you wanted out of your project.
However, when you compare each graph you do make less power (mainly tq.) from 3k to 5k. You can clearly see the dip in torque at 4k. I am a little over 500 where you are at 460ish and we are pretty close to the same at 4.5k and you pull away at 5k.
On the hp we are the same at 3k but I jump 30rwhp at 4k rpm at 5k we are pretty even and then you take off from there with the scavenging effect.
I am sure there is not much difference in lag vs my car when actually driving on the street, but the smaller cam is stronger in the mid range. Thanks for posting!
Example of a customer I have:
Guy was running a custom cam I put together and had ground for him (226/242). I then thoroughly tuned the vehicle to a perfect result everywhere. Car ran and drove beautifully and was running low 10's 1/4 mile (drag race guy).
He wanted more and I advised against it, but still spec'd out a new/bigger cam for him (246/258), kept lift the same, and lobe profiles were the same. I did my best to optimize a balance of the valve events between the 2 based on the difference in duration.
I am a professional tuner, and was able to get the big cam to behave reasonable on the street but not nearly as enjoyable to drive as the smaller cam.
The end result, the bigger cam made 25whp more at redline (7200rpm), but lost between 10-30 foot lbs of torque (this is HP here as well) almost everywhere below 5400 rpm. Went to the track and was consistently 3-4 tenths SLOWER.
I integrated the area under the HP and torque curves between 3000 and 7200 RPM and the smaller cam produced approximately 8% MORE.
Needless to say, we swapped the old cam back in because the car was faster and much easier and more enjoyable to drive on the street ha ha ha
Everyone is entitled to their own opinions though. I am just speaking from my experience (this is just 1 example).
