Power to radio when Battery disconnected
Old 04-24-2018, 01:22 PM
jshot00
jshot00's Avatar
Default Power to radio when Battery disconnected
I thought I read somewhere that there was a way to keep power to radio when you disconnect battery for replacement. Hate to loose all the preset stuff on the radio!
Old 04-24-2018, 01:43 PM
EVRose
EVRose's Avatar
You won't lose anything.
Old 04-24-2018, 01:59 PM
jaredtxrx
jaredtxrx's Avatar
You'll be fine.
You will only need to re-index your windows (and maybe seat presets).
Old 04-24-2018, 02:08 PM
jshot00
jshot00's Avatar
Even if it a aftermarket radio??
Old 04-24-2018, 02:20 PM
gliot1
gliot1's Avatar
Received 1,443 Likes on 753 Posts
St. Jude Donor '12-'13
Most modern radios, etc store the info to PROM, so will have no issues.
Old 04-24-2018, 02:29 PM
EVRose
EVRose's Avatar
That I don't know but likely yes, you won't lose anything.
Old 04-24-2018, 04:32 PM
bartsky
bartsky's Avatar
In Kenwoods at last you can save all your radio settings, and recall them after power loss.
Old 04-24-2018, 04:51 PM
Welker1
Welker1's Avatar
Have swapped batteries a couple of times since installing my Kenwood and have never lost any of my settings
Old 04-24-2018, 05:44 PM
FloridaC6
FloridaC6's Avatar
I have a Pioneer radio and replaced the battery this past weekend. All radio presets were saved. Only had to index the windows.
Old 04-24-2018, 05:54 PM
ruxvette
Support Corvetteforum!
ruxvette's Avatar
Received 3,597 Likes on 2,332 Posts
2016 C6 of Year Finalist
Back in the day I wired a 9 volt battery to a cigarette lighter and plugged that in when i unhooked the batt...not needed now.
Old 04-24-2018, 06:52 PM
RobJoy
RobJoy's Avatar
I guess by this message you're swapping the battery yourself. A battery shop knows to keep auxillary power on the car during the change-out.
Old 04-24-2018, 08:34 PM
Knob Jockey
Knob Jockey's Avatar
St. Jude Donor '11-'12-'13-'14-'15
This will work in a pinch.
Old 04-29-2018, 06:32 PM
jeffsolomon
jeffsolomon's Avatar
I have a little 9volt battery plug for the cigarette lighter that I use which I bought on Amazon for a few bucks, and have never lost any settings or window indexing when replacing or disconnecting the battery.
Old 04-29-2018, 06:55 PM
Corvette_Ed
Corvette_Ed's Avatar
Received 2,836 Likes on 1,799 Posts
When I've disconnected my battery, my Kenwood lost all equalizer settings. This has happened on two different cars. I don't use the radio so I don't know about the presets.
Old 04-29-2018, 10:01 PM
Knob Jockey
I've had my battery disconnected many times and usually nothing is affected (other than the windows, of course). I've never had to reset the stations on the radio,
As the car has gotten older I've had to reset a few things. The clock a few times, the steering wheel once, and the latest occurrence I had to reset the driver-side mirror.
Go figure.
To Power to radio when Battery disconnected
Quick Reply: Power to radio when Battery disconnected
