Tie Rod Adjuster Sleeve
Old 04-24-2018, 04:28 PM
sunflower 1972
sunflower 1972's Avatar
Default Tie Rod Adjuster Sleeve
I need to adjust the front toe on my 72. As near as I can tell, one COMPLETE turn of the adjuster sleeve moves the tie rods in or out approximately 1/16 of an inch. Correct? Just looking for confirmation of my findings. Thanks.
Old 04-24-2018, 04:39 PM
Mooser
Mooser's Avatar
Received 3,138 Likes on 2,069 Posts
IIRC they are 5/8-18 so one turn is 1/18" of an inch or pretty damn close to 1/16"
M
sunflower 1972 (04-24-2018)
Old 04-24-2018, 05:50 PM
sunflower 1972
M
Yeah, according to my "precise" measuring, it's just a tiny smidge more
than a 1/16". So, I'll say it's a 1/16" and go with that. Thanks M.
Old 04-24-2018, 06:09 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
Except that when you turn the sleeve, you are turning it at both ends...so it is spreading the equivalent of TWO thread widths.
Old 04-24-2018, 06:29 PM
sunflower 1972
Outer tie rod, adjuster sleeve, inner tie rod. Measured from grease fitting to grease fitting.Gave it one full turn. Backwards, forwards multiple times. Came up a smidge more than a 1/16".While sitting at my kitchen table. I do some of my best work sitting at my kitchen table.
Old 04-25-2018, 01:42 AM
7T1vette
7T1vette's Avatar
One revolution on an 18 thread screw should be .0555". So, that change at each end should yield slightly less than 1/8" (.111").
sunflower 1972 (04-25-2018)
Old 04-25-2018, 07:14 AM
Mooser
Mooser's Avatar
One turn of one tie-rod-end, in or out should be 1/18 change
One turn of the sleeve (as it would be on the car with both ends fixed) should be twice as much (1/9)
But whatever you need is whatever you need.
M
To Tie Rod Adjuster Sleeve
Quick Reply: Tie Rod Adjuster Sleeve
