WTB: Caliper bolt
OP - doesn't appear to be a C4 application in the snapshot so it's C4 for an adapter I'd guess of sorts to a 'project'. You need to confirm the under-head dimension you need and also M14 or M12. I would doubt that any of the kits would use M12 ('84 only hardware) but who knows.
Why wouldn't you buy specialty hardware 'local'?
The bolt if C4 front is M14x2x47 I believe. They're used on many GMs and available new 'off the shelf'. C4, C5 C6 and many more.
Thanks for the replies. I am new to Corvettes and have a lot to learn. I was told it was the suspension and brakes from a 94. It is going under my 63 with a frame I am having built. For some reason the bolt was missing. I went to the local Chevy dealer and was told it is no longer available. Is there a way to tell the year from the suspension? The bolt is a 14 mm.
Randy
Randy
Looks to be an 86-87 knuckle with the enclosed back along with the ABS shown in the background of the picture.
There will be a part number cast into the knuckle, post the number or a couple of more pictures.
Randy
Randy
14084051 is what you need if you want OE. If you want use the dimensions I mentioned and get some 12 point or whatever.
Show us the face of the caliper and mention the diameter of the brake rotor. ID will be simplified.
Whose chassis? SRiii or other?
