FS: Black Sport Seats/Partout
04-26-2018, 12:02 AM
Black Sport Seats Partout
As the title states, I have a set of black sport seat parts for sale.
Driver:
-Cover has tears, black duct tape is currently covering them ($80)
-Foam ($80)
-Power motor/track ($60)
-Power seat controller good ($30)
-Lumbar bladders ($40)
-Side bolster bladders ($40)
-SCM ($80)
-Wiring harness ($30)
-Fold forward lever (behind headrest) ($30)
Passenger:
-Cover has normal wear, no tears ($100)
-Foam ($100)
-SCM ($80)
I will get pics soon for these. Thanks!
04-26-2018, 08:57 AM
Interested in the driver's power motor/track; does it rock?, does it work? connectors good?
04-26-2018, 09:46 AM
Quote:
Originally Posted by
LannyL81
It does work, but unfortunately it does rock as well. Connectors are good.
04-29-2018, 07:45 AM
Do you know if the rocking would be fixed by replacing the washers in the thread block or is the rocking (like the one I have) in the track itself?
04-29-2018, 11:10 AM
LannyL81
I know that there are write ups on how to fix it. I believe you replace the plastic bushings
05-09-2018, 11:04 PM
05-10-2018, 07:31 AM
Can you provide the part # of the driver's side control module and verify that it was working when you pulled the seats?
Thanx
05-12-2018, 01:54 PM
fberus
Thanx
This is the control module directly under the seat cushion correct? Everything worked as far as I know. The seat went up, down, back, forth, side bolsters inflated & deflated, as well as the lumbar support. As far as easy access/memory, that I'm not sure about as no one else ever drives my car so the seat position never changed.
05-12-2018, 04:18 PM
I need to know the part number. There were at least two versions. The one I have isn't playing well with the rest of my power seat set-up so I want to try another version.
Thanx
05-14-2018, 11:23 PM
fberus
Thanx
10255407 sir
05-15-2018, 07:34 AM
Scholioso
10255407 sir
Sorry. I should have asked if your seats had memory. That is no-memory relay so I can't use it. Thanks for checking.
05-19-2018, 02:58 PM
09-18-2018, 06:39 PM
09-18-2018, 06:55 PM
would you have the recliner lever cover on the back of the seat at to top?
09-18-2018, 07:14 PM
1997 C5
Yes I do.
10-20-2018, 04:26 PM
10-20-2018, 07:05 PM
St. Jude Donor '14-'15,'19
do you got pictures
of the foam ?
10-20-2018, 07:59 PM
Driver side isn't great, passenger side is good.
10-21-2018, 07:42 PM
Cruising
I will take the driver side motor and track.
