How to remove Wax on fender lips
Well after a couple of dozen wax jobs i am seeing my hard black fender lips and mud flaps turning a grey color. Any one else use something to turn these back to the original color?
Thanks
Mark
Thanks
Mark
^^^^^ That would be my suggestion also.
Best thing since Sliced Bread! It's that good.
I have used Mother's 'Back to Black' for years but there is now some stuff that I feel works much better, protects and keeps my fender lips looking like "new" now for months. It's called 'WIPE NEW' and runs about $14. Follow directions, it just wipes on. It is clear and has the consistence of water, a little goes a long way.
After using this product the Mothers will stay on the shelf, it's that good.
Use the 'Wipe New' for trim, they also make stuff for flogged up clear light covers so make sure your buying the right wipe new.
I did our 2005 Vue body plastic which has been faded bad for years and it made it look like new again. It still looks that way 'many' months later. I'm sold.
PS: You may want to try using a tooth brush with warm soapy water to get most if not all of the wax off the plastic lips first.
Received 8,929 Likes
Use a different wax. I use Turtle Wax ICE. It doesn't leave a powdery residue that can get in the pores of the plastic. You can do the whole car with it paint, glass, plastic, rubber, etc. The only downside I have found is it will leave a smeary look right after it is applied but washing the car and towel drying get rid of that look. It also holds up well over time.
Bill
Bill
You're going to need a cleaner to get the wax off, hiding it with a trim dressing like "Back to Black" is just going to hide it for a few days until it burns off in the sun. Get something like Adam's eco APC or their Tire and Rubber Cleaner (Most brands make something like that but stuff from AutoZone and Wal-Mart are NOT the greatest). Anyways, a cleaner like that to break down the wax, de-oxidize the plastic, and THEN dress it with something like VRT or Back to Black if you must. There's better though.
Received 3,805 Likes
"Ask Tadge" Producer
A pencil eraser might work. Give it a try before you spend any money on cover-ups. :-)
Since the plastic surface isn't smooth (lots of little dimples with attendant small hollows between them) the wax goes into the hollows and drys there. When you try to wipe it off your towels can't get down in the hollows and that is what causes the discoloration. Over the years I have used all sorts of stuff to try and get it out of the plastic and nothing seems to work well. I have used Prep Sol Wax and Grease removers along with a fine soft bristled brush to no avail. You just can't get the solvent down into the hollows in enough quantity to dissolve all of the dried wax residue. Products like Black Chrome, etc just cover the wax but can't stick to it so that is why they provide a permanent solution. Even Armorall wiped on with a cloth will make it look good for a day or so but eventually it will be back to the way it was before.
Best thing to do is avoid any wax that leaves a visible residue no matter how great it is since no nobody will notice your deep take a swim in it shine if the plastic surfaces are whitish colored instead of black. Besides if the paint surface is in good shape most wax products will give you the same deep appearance if you use them correctly. The best wax in the world won't make a turd look any better.
Bill
Bill
DAC17 (04-28-2018)
I have come to realize over time how good some of the Turtle Wax products are like their bug & tar remover, its top shelf. I was using Mothers gold paste cleaner wax but now use Turtle Wax cream paste wax.
However I did try the Turtle Wax "ICE" a long time ago, I really did not like the results overall, it's a clear liquid you just wipe on so it really does not remove any surface oxidation like a cleaner wax would. It is also sitting on the shelf.
RoketRdr (04-29-2018)
Another option, although pricey, would be to replace the stock lips/spats with carbon fiber ones which are very glossy.
Montana Bob
I had the same problem and tried a bunch of the suggestions above. None of them seemed durable enough to last.
I ended up Plasti-dipping my Stage 1 splitter, spats and mudflaps and they now finally have there nice deep black semi-gloss color back. I might have to redo them once a year or so, but that can be one of the winter clean-up projects so I don't mind. At least I should be good for the driving season. Figured if I do any waxing in between, I just put some low tack painters tape on them.
Sonny
Sonny
