New from RPI Designs!!! C7 Corvette Vararam Cold Air Intake System
Platinum Supporting Vendor
Website Link: https://www.rpidesigns.com/shop/item...stem-vr-tcr-7/
If you are looking to increase to the performance of your C7 by adding an aftermarket air intake look no further than this new vararam intake. Veraram has been designing and building high-performance intakes for Corvettes since the late-90s. They have a proven track record of designing and building the most powerful intake systems on the market today. With their new intake C7 the VR-TCR-7 they bring decades of experience to the new C7 Corvette. Their new intake will provide an 18 to 20 hp increase without tuning and even more power if you retune your Corvette. Their precision injected intake has an amazing finish that looks like it is factory installed. This intake also features a true cold air induction that pulls cooler outside air from a high-pressure zone that gains added power without needing to cut up your Corvette. This intake also features same intake tube design as the COPO race program used for increased airflow. Installation takes only a few minutes with just a few simple hand tools.
This intake also includes a green high-performance air filter that is washable and reusable so you will never have to purchase another air filter again. This intake has two features not found on any other air intake on the market today. The first is the secondary air inlet. This draws cooler outside air from a high-pressure zone and will drop the intake air temperature in seconds to ambient air temperature for increased horsepower. The second feature is the reverse venturi intake tube. By expanding the intake to it helps pull the air off of the sides of intake and speeds it up causing more air to be fed into your engine providing additional horsepower. This intake is truly one of the highest performing and best-designed intakes on the market today and is sure to give your C7 Corvette a noticeable boost in performance.
TCR-7 Features:
Precision Injection and Rotational Molded construction for unprecedented quality.
Pulls additional airflow from a High-Pressure zone dropping heat soak temps in seconds, NOT miles like our competition. Gains of 1.2 – 4 % more power from Cold Air alone! No need to spend money
No tuning required. You can custom tune for more power.
Straight from the COPO Race program, Our Patented Reverse Venturi Intake Tube with throttle body Bell-Mouth for added flow. The result, flow is increased beyond having no intake at all!
Quick and Easy Installation. No cutting or drilling on your car.
Fitment: 2014, 2015, 2016, 2017, 2018 C7 Corvette Stingray, Grand Sport
Proper Heat shielding:
Dramatically delays heat penetration.
Proper Mold Quality:
ISO 9001 compliant manufacturing.
Smooth internally, near even plastic flow.
Maintains mold thickness
Requirements for strength and minimizing heat penetration.
Heat shielding?
The material did not stop heat soak during our real-world testing.
As you can see, its “OPEN” it can’t
Poor mold quality:
Moisture in the plastic.
Makes for a thin, flimsy, weak part. This also allows heat to penetrate quicker.
The differences are very clear!
The VR Reverse Venturi tube is the product of hours of CFD, Flow-bench and Racing development.
With expanding walls that can reach a massive 5.0 inches in ID combined with a gentle sweep angle and decreasing radius air horn to increase flow into the engine beyond vacuum alone. This combination flows far more volume while maintaining the velocity of a smaller tube. This competitor uses a standard ID bore that is “SMALLER” than factory and an “off the shelf ” 90 deg bend. Even GM didn’t do that!
TCR-7 Features:
Heat shielding?
Poor mold quality:
Thank you for the orders!
These make a great addition to any C7 Corvette!
If you would like to visit our Online Catalog for access to our entire
C7 Corvette Line of Parts and Merchandise Available for Sale,
just click the link below...
Website Link:
RPI Designs’ C7 Corvette Online Catalog
Forum Members,
Use Code
RPISHELLEY5
at Checkout for an Immediate Discount.
This Coupon Code is always Active
