Sponsored by: GEM Motorsports
Dyno Trip Today
Old 05-10-2018, 04:21 PM
MacRoadie
MacRoadie's Avatar
Default Dyno Trip Today
Today is the big day: car is off to the tuner to get a little more life programmed into her. As she sits, she's got a Tony Mamo PTB, AFE CAI, and a Borla X-pipe. Additional mods being done today at shop are: Innovators West 9% OD Pulley, Brisk RR10S plugs, Granatelli wires, and a 170 thermostat.
Old 05-10-2018, 04:24 PM
MacRoadie
MacRoadie's Avatar
Pre-tune pull.
Old 05-10-2018, 04:34 PM
MacRoadie
MacRoadie's Avatar
Pre-tune numbers. Dyno-Jet
Old 05-10-2018, 05:05 PM
DomLS3
DomLS3's Avatar
Any reason you decided not to get headers before tuning?
Old 05-10-2018, 05:20 PM
MacRoadie
MacRoadie's Avatar
California car. Even though it won't need to be smogged for another 5 years, I had to draw the line somewhere regarding how much I was willing to have to pull back off and swap back to OEM.
Old 05-10-2018, 05:34 PM
DomLS3
DomLS3's Avatar
Makes sense. Cali is the worst
Old 05-10-2018, 05:59 PM
Bob U
Bob U's Avatar
looking forward to seeing the final numbers.
Old 05-10-2018, 06:04 PM
MacRoadie
MacRoadie's Avatar
Me too.
Old 05-10-2018, 06:50 PM
sammyv
sammyv's Avatar
Subscribed. Auto or stick?
Old 05-10-2018, 06:57 PM
MacRoadie
MacRoadie's Avatar
Stick
Old 05-11-2018, 04:24 PM
SLEEKVET
SLEEKVET's Avatar
Just to clarify for myself, the 581.99 dyno numbers are from Tony Mamo PTB, AFE CAI, and a Borla X-pipe and stock tune?
Old 05-11-2018, 04:37 PM
MacRoadie
MacRoadie's Avatar
Yes, PTB, X-pipe, and CAI. Stock tune. Car has Boostane in the tank, blended to +/- 95 octane but that shouldn’t matter. I’ve heard DynoJets show high on HP, but he mentioned before the pull he usually sees 510-520 range on A8’s and I don’t now if that indicates where the dyno falls on the high/low scale. They don’t see too many M7’s for comparison.
Old 05-11-2018, 04:49 PM
SLEEKVET
SLEEKVET's Avatar
I have an A8 and not too far from that area and shop. Thanks for sharing. Look forward to your results.
Old 05-11-2018, 05:09 PM
MacRoadie
MacRoadie's Avatar
They do all the tuning for West Coast Corvettes, Corvette Mike's, and a few other in So Cal.
As I understand it, a 2017 M7 should be putting down somewhere in the range of 540 to 550 stock, with the A8 coming in a little lower. If we "give" the mods say 10-15 HP each for the PTB and the CAI, then 582 at the wheels isn't too outlandish.
I screwed up and somehow lost the crank bolt and washer, and had to order a new one from Innovators West (who aren't really "west" as they're in Kansas) and am getting it overnighted to So Cal for installation Monday. Gonna be a looooooong weekend.
SLEEKVET (05-11-2018)
Old 05-12-2018, 09:49 AM
Z06-MAN
Z06-MAN's Avatar
I have a M7 16Z, only have a BMS air filter and Mayo TB, put down 589 HP and 611TQ in RI at sea level on a hot summer day last year. Did back to back pulls on a Dynojet.
Old 05-15-2018, 02:15 PM
MacRoadie
MacRoadie's Avatar
It had a bump from the new throttle body and intake, so the HP gains are less pronounced than the TQ. I’m guessing it was at about 550 HP off the lot. Probably above 700 HP at the crank now.
Torque profile is MUCH smoother and comes on earlier. Also AFR is dead smooth all the way across. 2 psi more boost as well with new pulley.
Old 05-15-2018, 03:03 PM
ajrothm
ajrothm's Avatar
Received 1,095 Likes on 746 Posts
Hell it gained HUGE through the low end and midrange....Like 100hp gain.....Up top was good for 40....
You'll feel that midrange gain BIG TIME.
To Dyno Trip Today
Old 05-15-2018, 03:12 PM
3 Z06ZR1
3 Z06ZR1's Avatar
have your shop reprint the sheets in SAE instead of STD
the numbers are more comparable to others.
Old 05-15-2018, 04:25 PM
MacRoadie
MacRoadie's Avatar
Yeah, I might if I have time. I’m more interested in the relative numbers rather than the absolutes.
Old 05-15-2018, 05:22 PM
NicD
NicD's Avatar
FYI it only looks like it gained a ton of torque from 3000 rpm to around 5250 rpm because it was spinning the tires on runfile 3 and it wasn't on runfile 7. The large super smooth upside down curve shape or depression is a dead give away of tire spin on a dynojet.
Quick Reply: Dyno Trip Today
