Help a new member with R888R tires option
Hi there guys, been following your job in corvett fórum, great forum!!! i have a question(sorry maybe this question is already here). I love how my R888R tires Works on my other cars and will love to use on my Z06 C7.
I have seen this front 285/30/19 stock and so im thinking to get the size 265/35/19, add for the 335/25/20 fit the 285/35/20. Any suggetion?. Do you think it till work?.
Regards,
Regards,
Received 1,762 Likes
ttt
Those two tires is to much off I am thinking your will get a code & a brake paddle pushing back at you when you put the brake on r push the brake down.
c0777 (05-14-2018)
Thanks a lot for your time and fast reply.
I just ran a set of 285/30/18 & 335/30/18. Worked great other than I used half the tread in 3 20 min sessions. Your going to need some after market wheels. Bright side is I just picked up a set of triple 8’s in 18’s for $1200 shipped. About $600 cheaper than the same tire in 19/20’s.
Sr.Random input generator
+1, let us know what you figured out, and what your setup is like, including alignment and cold/hot pressures.
Whenever premature wear happened to me, it ended being either alignment issue or too low pressure, overheating the tire.
Good luck!
Good luck!
I’m looking at 315/30/18 front and 335/30/18 rear. Will overall diameters this close work ok with PTM? I know you did a lot of tire testing in your build thread. Thanks for all the knowledge - very helpful
My take away, even used heat cycled R7 have more grip and last longer a new triple 8R. At lest how I drive with my set up. No shock, but good for my brain to understand the effect.
IMO uneven wear on track used tires is indicative of other problems, like alignment or tire pressure. Especially if you run without traction control. Going to a wider tire doesn’t solve the root of the problem.
het a tire temperature gauge (or any old infrared thermometer) and take tire temp across the inside, middle, and outside tread surface of each tire and it’ll tell you far more about why the tire isn’t wearing event, then you can go about solving it by making changes in drivno style, alignment, tire pressure, or changing size in tires.
The abnormal center wear might indicate too high pressures. Did you monitor the tire pressures during your runs? R888 was notorious with sensitivity to tire pressures on how it behaved. If it shot up to 40+ PSI, for instance, it could have caused more wear at the center.
I'll be testing out brand new 315/335 R888Rs myself at the track, this weekend, and will compare to brand new 295/315 RRs. I just wish we had a 335/30/18 size on RRs : )
It does work. C7 in general is much less sensitive to diameter differences than C6.
The only issue that I've ever seen regarding diameter was when I tested out 285/30/18F 295/30/18R Hankook TD221s: I noticed traction control being too sensitive on touring mode. It did not impact track / competition mode, however, so it was a trivial issue for me. In any case, I've never seen any error message, etc.
Yeah, R888R kinda suck due to temp sensitivity and having crappy traction (for what they are). Unfortunately, I can't think of a better tire for a reasonable price that I can drive to the track on.
