Catch Can routing on Boosted C5
I'm sure this has been covered but can't find a straight answer. I currently running the MM wild catch can on my 02 c5z that has an A&A V3 t-trim. As of right now, my "clean" line is going to the intake on the S/C and the "dirty" side is from the oil fill cap. Is this correct and if not, what's a better option? Thanks in advance.
Running Guns & Moonshine
I have an older .pdf for the Rev Extreme piece, and it looks like this is their intent for LS6 with centri.
For my LS1-based rig, it is a bit more complex and I have two one-way check valves instead of one with my CoSpeed piece. Come to think of it, they also recommended and then sent some sort of in-line restrictor for mine as well.
Scotty_Z06 (05-15-2018)
The following 2 users liked this post by 69GTO96Z:
David@MMS (05-17-2018),
Scotty_Z06 (05-16-2018)
This needs to be stickied, I feel like I see this question once a month.
I also have my catch can run per the MM specs with a breather filter on the valley cover barb.
I have the MM pcv can. Intake manifold to can pcv, passenger valve cover to can 10 an line and ls6 valley barb to fresh air in supercharger filter. Drivers valve cover is blocked off.
Received 1,261 Likes
That sounds like a vacuum leak... Intake manifold vacuum sucks air through the can and engine, from the atmosphere, coming in that filter. Granted, not a large vacuum leak, but wouldn't it be better to run a hose from the valley barb to a fitting located downstream of the MAF sensor? Then the engine would only pull in metered air.
I think the proper way TBH would be to run the valley barb to the air filter pre-SC?
Well, damn... I was picturing my Subaru's setup where the MAF is upstream of the compressor. With a blow-through MAF there is no place that's both downstream of the MAF and upstream of the compressor. Moving the valley barb to the pre-SC pipe would only fix the metering problem if the MAF upstream of the fitting.
IIRC MM said the basic concept was to get dirty fumes out / clean air in. The driver's side valve cover should be the clean air input but mine has a grommet. I figured the valley cover barb would do for now for air intake.
There's a line from the MM catch can to the intake but it the can has a check valve on it to prevent boost from reversing the air flow.
Yeah, SD makes vacuum leaks kind of a non-issue. Maybe I shoulda kept my trap shut.
Supporting Vendor
a pcv system is a controlled vacuum leak when possible helps the computer to have read this air through the maf, but if boosted maf not possible and if SD no maf.
there are also times when you simply cannot or do not want to connect to the main air filter tract, so, knowing the above, a separate filter can be used.
For MAF-based fueling, that'd be pulling in unmetered air - also known as a vacuum leak. But he isn't using the MAF anyway, so it's no big deal.
I had my tb off last night to reroute wiring under it while putting in a new mafkess pipe and saw that there is oil entering the intake via the pcv with the current system I have. While I'm sure that's fine and no different from factory function, therein is the frustration... No difference from factory function. The tank is certainly not full either.
Supporting Vendor
even the best cans are not 100% efficient, and it goes down from there!
if you are looking to improve on your current situation i'd love to help!
__________________
Solutions for the common gearhead #made in USA
mightymousesolutions.com
facebok.com/mightymousesolutions
#mmsolutions
Six time NMCA True Street Champions
Home of the first Twin Turbo C7Z 7.81 @ 176
3470# Stock bottom end and heads Corvette Stock Bottom End Record Holder
#mmsolutions
I did check your site to see about exactly that, and I may swap over soon. For the moment, I have more pressing projects to complete on the car.
For blown applications with headers, where/how would your kit mount?
