C7 ZR1 Discussion General ZR1 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Underneath the new ZR1
Old 05-17-2018, 08:53 PM
Poor-sha
Track Rat
Support Corvetteforum!
Poor-sha's Avatar
Received 3,400 Likes on 1,372 Posts
Default Underneath the new ZR1
I decided to make a video of the new ZR1 up on a lift. It covers a few interesting details that you can't see from above. I hope you enjoy!
The following 22 users liked this post by Poor-sha:
BERETTA (05-17-2018), Corvette_Nut (05-17-2018), D'ZR1 Messiah (05-21-2018), desmophile (05-17-2018), DoctorV8 (05-21-2018), G fix needy (05-17-2018), Harris (05-18-2018), Kappa (05-17-2018), Lavender (05-18-2018), LoveTwoFly (05-22-2018), MMartin (05-22-2018), morepwr (05-18-2018), NewYuriCity (05-18-2018), Palantirion (05-20-2018), Pizz (05-18-2018), Quiky One (05-18-2018), RapidC84B (05-18-2018), RJ-92 (05-18-2018), RoketRdr (05-18-2018), Rookieracer (05-17-2018), Tmill (05-18-2018), WilliamCall (05-17-2018) and 17 others liked this post. (Show less...)
Old 05-17-2018, 09:04 PM
Anthony D'Aloisio
Anthony D'Aloisio's Avatar
Thanks! Like em dirty lol.[/left]
Poor-sha (05-18-2018)
Old 05-17-2018, 09:24 PM
UnhandledException
UnhandledException's Avatar
Received 1,351 Likes on 554 Posts
Very nice, thanks for the video.
Old 05-17-2018, 09:36 PM
charles7970
charles7970's Avatar
Awesome! Keep videos like this coming! Thank you
Old 05-17-2018, 10:18 PM
Corvette_Nut
Corvette_Nut's Avatar
Location: Hailing From The Mean Streets Of Irvine, California
Received 4,153 Likes on 1,314 Posts
Thank you for posting!
Old 05-17-2018, 10:44 PM
Bob U
Bob U's Avatar
Awesome, thanks for sharing.
Where did you get the stud extensions?
Great idea, I like them.
Old 05-17-2018, 10:59 PM
rico750sxi
rico750sxi's Avatar
They are from Reverselogic, they are pretty handy if you take your wheels on and off a lot.
Bob U (05-18-2018)
Old 05-17-2018, 11:19 PM
JCSIII
JCSIII's Avatar
I get the deflector to direct some air into the exhaust tunnel to add some cool air to that area, but wonder why you add 2 plates to cover the front holes. Must be something to do with the air flow. Why not have deflectors there also? Wonder if this could help the Z06? Reminds me of the black plastic deflector under the differential on my c7 z51, my C7 Z06 doesnt have that piece.
Seems like the new intercooler exit ducts dumping into the wheel well would add heat to the brake area. Same as the LG solution, guess it's not significant haven't heard it being an issue for the LG system.
Wonder if the rerouted brake cooling duct is better or just due to the intercooler and had to be that way. Might be able to add a tube on the Z06 if better.
Old 05-18-2018, 12:11 AM
RapidC84B
RapidC84B's Avatar
Received 13,153 Likes on 5,984 Posts
When did that brake duct kit come out? My Z51 just has the "flaps" that bolt to the LCA and the ducts blow into the wheel well like the C5 did.
Old 05-18-2018, 12:20 AM
wwx8989
wwx8989's Avatar
Thanks a lot for showing us some the unseen part of the car, I’m wondering if you can share the ZR1 Spring part number if you got a chance.
Old 05-18-2018, 01:04 AM
jdmvette
Night Owl for life
jdmvette's Avatar
Received 3,247 Likes on 1,668 Posts
Old 05-18-2018, 07:32 AM
Kappa
Kappa's Avatar
Almost all cars with cheek mounted radiators have a similar setup these days. To me the only thing I’d be worried about is creating
more lift but I’m guessing it causes a negligible amount.
Old 05-18-2018, 08:21 AM
JCSIII
JCSIII's Avatar
Been out at least a year. I think they started on 2017's (see part number below) the new part is the tube leading to this setup.
GM part number
2017 C7 Corvette Z06 Track Front Brake Duct Cooling Kit 23412348 (23412348)
Old 05-18-2018, 08:46 AM
RapidC84B
RapidC84B's Avatar
GM part number
Looks like it supplements the stock ducts and catches air with the scoop on the LCA vs. the nose. On the ZR1 they feed the nose ducts to the LCA scoops. Wonder if the LCA flaps stay in place or if the new scoops replace them?
Old 05-18-2018, 12:04 PM
RJ-92
RJ-92's Avatar
Correct, the lift is negligible. The open wheel designs and front aero pieces create plenty of leaving the fender-well area, that what little positive pressure created is insignificant.
Regarding the hot air and the brakes, The air exiting the radiator is likely no more than 240* with hard driving. Brakes can get well over 500* ~250* difference. It may not help to cool the brakes (that's what the brake ducting is for) but it sure won't heat them either.
Old 05-18-2018, 06:51 PM
Poor-sha
Track Rat
Poor-sha's Avatar
If you look at the opening in the nose it actually splits. One channel feeds the tube that blows into the duct that is under the LCA. The other one goes in to the wheel well area where it catches the deflectors like the Z06. The big difference is this route straight from the nose in to the duct that routes to the center of the rotor, that should work a lot better than just trying to catch the air hanging under the car.
Old 05-18-2018, 06:54 PM
Poor-sha
Track Rat
Poor-sha's Avatar
Originally Posted by rico750sxi
They are from Racelogic, they are pretty handy if you take your wheels on and off a lot.
Reverse Logic
http://www.reverselogic.us/lug-guides.html
Bob U (05-18-2018)
To Underneath the new ZR1
Old 05-18-2018, 07:36 PM
rico750sxi
rico750sxi's Avatar
Originally Posted by Poor-sha
Oops, fixed my post. Thanks
Old 05-18-2018, 08:17 PM
dvandentop
dvandentop's Avatar
good video didnt know about the cooling plates for exhaust
enjoy the new ride
Old 05-18-2018, 08:57 PM
Bob U
Bob U's Avatar
Thanks
Quick Reply: Underneath the new ZR1
