[C2] 1965 L79 Oil Gauge (60 or 80)
Does anyone know for sure which pressure gauge the L79 engine had in the dash, 60 or 80 pound? Thanks for any help.
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
VetteZr (05-19-2018)
VetteZr (05-20-2018)
FWIW.
Larry
EDIT: Neither Rick Miller's Book on C2 Corvettes or Noland's Book on C2 Restoration show anything different regarding the oil pressure gage from what is stated in the NCRS JM.
My 1965 NCRS Judging Manual indicates 60 psig gage for both EARLY and LATE L-79 engines.
FWIW.
Larry
FWIW.
Larry
VetteZr (05-21-2018)
Thanks for that input, I guess I'll have to go with the NCRS book on this one.
FWIW.
Larry
FWIW.
Larry
Here's my first car, VIN 04835, picture taken May 1968; had 32,600 miles. L79 (350hp), no radio, had back-up lights but no day/night mirror. Didn't know at the time that it was such a strange bird. Notice the 80 lb oil gauge.
I went back and rechecked Rick Miller's and Noland's Books. Had a bit more time to search. Nothing I could find in Noland's Restoration Book about the 60 or 80 psi oil pressure gage changes.
However in Rick's Book I found two references to the L-79 with the different oil pressure gages that i did not find earlier. One was on page 65 regarding inspecting a prospective corvette for purchase. Rick stated here that some 1965 L-79 cars had an 80 psi oil pressure gage and early L-79 also had the low 5300 RPM redline tachometer.
On page 140 regarding the 1965 specific model year corvette, Rick showed a picture of the instrument cluster of a 1965 car (engine/car not identified) that had a 5300 RPM redline tachometer and a 80 psi oil pressure gage. Rick stated that this suggested that it was an early production 327/350 (L-79) engine.
So there is evidence from his book as well as forum members midstyle and cblankin that the 80 psi oil pressure gage did exist from the factory.
There is no additional knowledge I can find that ties this difference to a particular VIN range or month of production. Midstyle's picture shows the higher 6000 RPM redline tach for the L-79 along with the 80 psi oil gage..........so the oil pressure and tach redline changes were not done together or simultaneously.
The NCRS 1965 Team Leader may have additional info and could be contacted. His name is K.C. Strawmyre from Newburg, Pennsylvania. You can PM me for contact information.
Received 1,843 Likes
Was the 80 lb gauge used with the six quart pan? 60 lb gauge used with the five quart pan?
Received 6,940 Likes
2015 C2 of Year Finalist
Larry
