WTB: NOS Drip (roof) Moldings for Z06
Or at least the driver's side.
ttt
oneandgone (05-26-2018)
Thanks for the info. Why do you need the retainer too?
It generally gets bent or otherwise damaged upon removal to replace the plastic piece underneath.
Yes it does. I tried to remove it gently but no way. Also if you use the GM parts they come with the rubber between the drip rail and windshield already attached. The track comes with the weatherstripping tape, that goes between the track and the drip rail, already installed. I used the 3M rope seal between the roof and the drip rail. Water tested and no leaks.
Very good, thanks. As I understand it, that part number and molding will not fit the Z06/FRC. I believe the Z06/FRC is no longer available through GM, that's why I'm hunting an NOS pair elsewhere.
I'd entertain a good, used, driver's side. Chances are it's going to split like mine before long though, so I'd rather find a new one that hasn't seen the sun yet.
10331562 (right side)
10331563 (left side)
These are for the FRC/Z06. They are showing as available on gmpartsdirect.com for $186 each plus shipping. Probably about as cheap as you are going to find them anywhere. I got a set from them last year.
