Common Tripower-Problem
Hi folks,
I have a probably common problem by maintaining my (Holley) Tripower-Setup on my ’69 L68:
When connecting/disconnecting the fuel lines from the carbs, I have to hold the big (1”) nut, while tighten/loosen the fixing-nut for the fuel-line. Unfortunately the space between the big nut and the carb-housing is too small, to use a normal open-end-wrench, so I can’t grab it tight enough. A ring-wrench won’t help, because it can’t be fixed while the fuel line is connected. Beside there isn’t enough space for it either.
Is there any special tool for that work? Or do you have genious idea to solve that problem?
Interested greets from Germany
Gerrit
Gerrit
Here you go.
https://www.ebay.com/itm/Snap-On-12-...r0w16teXdJnx0Q
I bought a collection of these for my Vintage Air install and to torque a/c hoses/tubing. I discovered lots of other uses too.
Hope this helps.
Hope this helps.
I've controlled it that afternoon - it's one inch in size!
Gerrit
You got me thinking, so I had to go look at mine. 13/16" nut Maybe try finding a Mac Tools S141 wrench. It is about 3/16" thick. It's what I use on quadrajets
I made my own tool. I will post a photo of it tomorrow.
Keep in mind that I made this when I was assembling all of the fuel lines.
DUB
DUB
This tool I fabricated works perfectly.
DUB
DUB
Fine work
But it works only with disassebled fuel-lines because it has no cut-out. I fear, when cutting out a piece for sliding it over the fuel-line, it won't be strong enough, because it's too thin in material ....
I've ordered the "crow-foot" and hope, it will fit ...
Gerrit
Gerrit
I know it only works when the liens are off. I wrote that in my first post on this thread.
For me...removing the line or lines to get the fitting correct is not that big of deal. I am not looking for what is fast..because many of these flare wrenches will not fit due to how thick they are. I do not want to damage the fitting due to trying to do what is faster. The last tri-power that I needed to use this tool. Stopping the leak at a fitting took about 5 minutes ...if that.
The tool I made works PERFECTLY. On all three carbs. No damage to the brass fitting and it fits like a dream. I had bit of concern that I needed to use a six point socket instead of a 12 point socket...but so far. This one works and I can get in and get a hold of the fitting and do what I need.
I will BET that if you get crowfoot flare wrench..you will need to grind on it to make it fit...hence...weaken it.
I hope whatever you get works for you because if the tool slips off and rounds that brass edges of the fitting. AS you know...NOW you are in a world of HURT. Which is why I made mine like I did so I did not have the take the carbs off the intake. I do not need to mess up ANYTHING on an engine like this. And time gets thrown out the window due to the engine deserves the best possible.
Hope you idea works for you.
DUB
DUB
Seems like lot of trouble and expense if you ask me...when clearly there is a method that can fix your problem.
Even if you change out that fitting. I BET you are STILL gong to have a clearance issue on the center and rear carbs.
Do as you wish. Brain storm on it and figure something out. And when it is all said an done ..I hope your idea works.
And in my last post I was incorrect. The fittings are not brass...although some are that I have seen some on other carbs. Sorry for any confusion. But that still does not mean the edges can not get wiped out and rounded off.
I have nothing more to give you due to you have already gotten HOURS of me figuring out and fabricating and testing what was the best alternative I could come up with when I work in these and do NO DAMAGE. I do this stuff for a living so TRUST ME..I try to find the best way that is the quickest. Sometimes it is just what it is. I could have simply ignored this thread and done nothing. But I thought I would help as much as I can..and I did. If what I provided does not suit you and you feel can do better in re-inventing the wheel. Best of luck in your quest and as I wrote before...I hope it works for you.
DUB
DUB
Do You think, I just can switch to the smaller nuts - just "plug & play"? Do I need anything else?
And - as a main problem for me here in Germany -: where I can get those smaller nuts?
And to DUB:
Regarding your self-made tool I guess, how you will lock the nut, while fixing the fuel line - and take the tool away afterwards? Most I needed such a tool to lock the nut while fixing the line, to prevent the big nut for turning while fixing ... But I agree, that I probably will have to grind the crow-foot for a perfect slip on the nut in place.
Gerrit
And to DUB:
Gerrit
Because the fuel line that is going into the fitting in the carb..is also connected to the brass junction block that CAN be removed.
With the BRASS BLOCK out of the way...but the steel line still in the fitting...it can be tightened..or loosened so the fitting can be tightened...so...my tool can slide off the fitting and the line.
YES..IF the line that goes into the fitting wants to move...then with my tool on the line so it can hold the fitting in the carb. You reassemble the BRASS BLOCK temporarily so the line holds it position so you can tighten it at the carb fitting...THEN remove the brass block to get my tool off.
Not a big deal at all.
DUB
