Any pre-2019 Z06's switching to 0w40 Dexos2?
Just curious if anyone is switching to the 0w40 as GM is now recommending for the Z06? I have a 2016, I can't imagine that anything materially changed in the LT4 engine from 2015-2019. Thinking that the new requirement is good insurance for both GM and us owners. I may be a little paranoid as well as I had my first motor replaced at 15K miles for a bearing failure. #2 journal bearing failed and ate itself. All others were fine.....really a strange failure. My thought was a machining error, wrong bearing size, no oil journal, etc.
Anyway, anyone switching? Looks like Mobil 1 and Castrol all have 0w40's with Dexos2 certification.
https://www.centerforqa.com/dexos-brand2/
Castrol Edge dexos2™ 0W-40 GB2C1214082
Mobil 1 ESP dexos2™ 0W-40 GB1A0917015
Mobil 1 ESP Formula dexos2™ 0W-40 D20679HJ015
Anyone who is not an engineer cannot have any experience or knowledge of what takes place on any high technology business. Failures, both those easy to understand and those that are more unusual will. Always occur with any device. No sense worrying much about them here, other than beating them to death with people who do not understand the engineering involved.
I use the ESP oil in my 2016 Z06 because Mobile, or any company in person involved with technological products knows orders of magnitude more than any of us, even though I am an engineer in a different discipline. Will all recommendations work out - no, of course not. That”s life in the real world I”m afraid.
DAC17 (05-20-2018)
I had my dealership change my oil last month with the new recommended 0-40. This was my regular track prep that they do for me with the brake flush with dot4. This oil will keep me from having to do oil changes after every track day as i do street drive my car a little. Car is 2015
I changed to 0 -40
I had my dealership change to 0 - 40 Mobil 1. It was the most expensive oil change the dealer has ever done ($182). I had them order a case of the oil and had them slip the other 2 and a half bottles in @ $11.32 each so it ended up $135.82 just for oil. After I did find it online for ~$7. Don't know why there is a sticker on the bottles that they are not for sale to the public. I just had the car at Lime Rock for 2 track days and oil consumption was the same as 5 - 30. I have a 15 Z06 with 20K on the odometer.
Received 3,117 Likes
Finalist 2020 C7 of the Year -- Unmodified
Do we need this oil change if we do not track our Z06's?
No and the 5-30 oil is just fine more important to make sure to use a PF64. To pay 182 for an oil change? I get two 5 qt jugs for less than $50.00
As stated above, manual calls for 15w50 for track use, let's not void someone's warranty for using the wrong oil during track use. New manual appears to state that 0w40 is now approved. Hence the thread. I'd like to see GM update for all MY's 2015 - 2018.
I'm the OP, but yes I missed that, SORRY. Can't find any updates for the 15-18, just the 2019.
http://gmauthority.com/blog/2018/02/...m-the-factory/
New oil
To the OP: I was wondering the same thing. Just got an 18' last week. No mention of a new type of oil or why. I called a service advisor and he seemed clueless. What's the difference? There's no mention of it for Zl1's (which I traded). Same motor. 18 or 19, no difference. Must be an environmental issue.
Appears to be both a performance (oil performance) and a catalytic converter longevity issues.
The 0W-40 began in Europe but in the USA we require the ESP spec oil for GM vehicles.
What is the ESP part of the Mobil 1 Oil specification? Low Sulfur & Phosphorous Content: Helps To Reduce Poisoning Of Gasoline Catalytic Converters. This is a major problem for newer cars. In the past high Phosphorous oils were destroying catalytic converters. In response to this manufactures have lowered the additives to extend the life of emission systems.
High Phosphorous oils attack the converter matrix coating and requires replacement of the converters when they fail. This is typically detected from the monitoring O2 sensor downstream of the Catalytic Converter.
On the flip side, older engines that depend on the additional phosphorous content to extend the life of metal to metal contact parts such as camshaft lobes began to fail. If you own an older engine without roller camshafts pick your oil wisely!
