[C2] PB Booster check valve
Sure. Just blow into it from where the hose connects and should not pass air. Try it the other way and it should pass air. Use your mouth - not an air hose.
Verne
Verne
66RBS (05-20-2018)
That's it; the 'ole blow/suck check - also how I check vacuum advance cans with a rubber hose.
PUBLIC SERVICE ANNOUNCEMENT:
Don't do it in front of your pals though - you'll never hear the end of it
So I applied vacuum to the engine side and it held a vacuum about 11 “ hg. I applied a vacuum to the booster side and no go.
So I guess it is working
Your service manual will have the other three "in car" checks to make sure the valve works, the internals are good and the vacuum reserve is sufficient...
