What oil percentage do you let your oil get to before changing it out?
Old 05-20-2018, 09:59 AM
Always Red Dave
Always Red Dave's Avatar
Received 3,109 Likes on 1,734 Posts
Finalist 2020 C7 of the Year -- Unmodified
Default What oil percentage do you let your oil get to before changing it out?
I change my oil every year no matter how much mileage I put on in that year which is usually no more than 2000 miles a year. Do to time monitoring in the oil life system what oil percentage do you let your car get down to before you change the oil. For instance mine is going in for its second oil change tomorrow with 981 miles on the clock but the oil monitoring system says I only have 27% left. That is only 500 miles from my first oil change.Thanks Dave
Art17 (05-20-2018)
Old 05-20-2018, 10:02 AM
dvilin
dvilin's Avatar
Received 7,922 Likes on 4,808 Posts
Once a year for sure like you due to it being in storage for the Winter otherwise when the oil monitor gets around 25% or less I take it in.
Art17 (05-20-2018)
Old 05-20-2018, 10:10 AM
laserdude2215
laserdude2215's Avatar
Zero percent for me!
The following 2 users liked this post by laserdude2215:
CP (04-02-2019), white90conv (05-21-2018)
Old 05-20-2018, 10:12 AM
dbaker
dbaker's Avatar
5% or 5k miles,whichever comes 1st.
\db2
Old 05-20-2018, 10:22 AM
robertbruce
Support Corvetteforum!
robertbruce's Avatar
Received 3,222 Likes on 1,580 Posts
3000 to 3500 miles
Old 05-20-2018, 10:29 AM
CP
CP's Avatar
Received 1,125 Likes on 562 Posts
Wasting money
\db2
Wasting money
Originally Posted by robertbruce
3000 to 3500 miles
Wasting money
Why do some people think they know better than the folks that designed and built the engine and cover it with a warranty?
Steve_R (05-20-2018)
Old 05-20-2018, 10:35 AM
saleen556
saleen556's Avatar
Received 2,202 Likes on 1,193 Posts
Sounds like you only need to worry about doing it annually. The oil does degrade just sitting there. Also it sounds like someone is going to get a killer deal when you get tired of looking at it sitting in the garage.
Old 05-20-2018, 10:36 AM
dvilin
dvilin's Avatar
Originally Posted by CP
Wasting money
Wasting money
Wasting money
How much money are you saving by letting it get to zero versus 25% or less. Really no big deal either way, certainly not wasting any "real" money in my world.
Old 05-20-2018, 10:45 AM
bigblock427
bigblock427's Avatar
Received 1,346 Likes on 1,057 Posts
Mine Vette is a daily driver. Normally, I have mine changed between 5 and 10 percent, in order to avoid not being able to have it changed prior to zero percent.
Old 05-20-2018, 10:53 AM
davepl
davepl's Avatar
Received 1,500 Likes on 987 Posts
0% or annually, whichever comes first.
blkvet6 (05-20-2018)
Old 05-20-2018, 11:25 AM
Corgidog1
Corgidog1's Avatar
Received 2,523 Likes on 1,482 Posts
I change my oil annually when I take it from its winter haitus in march or april. Percentage is usually 0 or pretty close as I only have 5400 miles after 3 yrs.
Old 05-20-2018, 11:46 AM
spireland
spireland's Avatar
Received 2,147 Likes on 877 Posts
Wasting money
Wasting money
Wasting money
Because oil is cheaper than engines.
Maintenance schedules are done when looking at how an entire fleet should be okay with. Your care is a 1 of 1 statistic. Why risk it for a few extra bucks?
Old 05-20-2018, 11:52 AM
Sellout
Sellout's Avatar
exactly 1%
Old 05-20-2018, 12:12 PM
Internets_Ninja
Internets_Ninja's Avatar
Received 1,286 Likes on 846 Posts
As close to 0% as time allows since I change my own oil. 3000-3500 miles is a huge waste of time and a small waste of money in my opinion. Unless that is all the miles you've accumulated in a years time.
Old 05-20-2018, 12:55 PM
tomtoro
tomtoro's Avatar
Once a year. I put about 5k per year on mine and use the Mobil 1 15k synthetic (redundant?).
Old 05-20-2018, 01:22 PM
sunsalem
sunsalem's Avatar
Received 2,146 Likes on 1,521 Posts
Exactly.
I wait until the people who designed the engine send me a message on my dash display before I change mine.
CP (05-20-2018)
Old 05-20-2018, 02:19 PM
Jaykoh-Z51
Jaykoh-Z51's Avatar
Is the oil ‘counter’ based on time, mileage or some kind of combined algorithm?
does it actually “see” the oil’s condition somehow. (Doubt this level of tech). Aircraft engines don’t even have that. But figured I’d ask.
To What oil percentage do you let your oil get to before changing it out?
Old 05-20-2018, 02:39 PM
JerryU
E-Ray, 3LZ, ZER, LIFT
JerryU's Avatar
Received 9,619 Likes on 6,625 Posts
At about 10% life left it starts telling you to change every time you start. You can clear the message but about then is the logical time to change. I change mine about then.
Since no one discussed it, it is a complex algorithm BUT as you suspected it does not measure the oil.
I'll mention some things it does but first this is what it said in my '93 Vette Owner's Manual.
1) Change at 7500 miles OR one year which ever comes first.
2) If most Trips are under 4 miles change at 3000 miles or 3 months whichever comes first!
In '93 the only thing measured was miles and they had to guess what to do IF you mostly made short trips,
The worse thing for oil is starting, not letting the oil get to temp (175 to 190 F) for long enough to evaporate some of the excess products of combustion that pass cold pistons. One main product is water that will form acids etc. To keep a cold engine running they also use a richer fuel/air mixture so that also passes the cold pistons that have more clearance to the cylinder walls until the pistons get hot. In fact the worse thing is pulling a car out of the garage to get something it is blocking and putting it right back!
The OLM measures many things, for example engine revolutions made. A much better measure than miles, i. e. a mile around town is much tougher on an engine and oil than a highway mile! It also monitors the oil temp after a start. If it does not get hot enough long enough to evaporate the excess blowby from cold starts, it will shorten the time to change. It is also the first Vette to keep track of time for you! So assuming those few miles you put on are not all 2 mile trips to the store and back in one year it will say change!
Hope that helps understand what it does and why it is better for very low mileage cars than change every 3 months that it said in the past before the OLM was introduced!
The following 2 users liked this post by JerryU:
BrookenookZO6 (05-21-2018), Widgeon5 (04-01-2019)
Old 05-20-2018, 04:28 PM
Jaykoh-Z51
Jaykoh-Z51's Avatar
Jerry...excellent description. Those of us on here that are very tech orientated or have to deal with similar at work, I crave/want that level of knowledge of certain things. I'm an airline pilot so thats been my life for 20 years. "Why/When does this light come on". etc.
I'll promise you I'll bug you again in the future for other knowledge level questions about our rides.
I was concerned the OLM was really just a dummy timer for the average person who NEEDS the reminder. I'm very glad to learn that it actually has quite a bit of logic built in. I'll definitely trust it now. I haven't tracked yet and I know that kind of oil care is a different animal. But day to day driving....awesome.
Old 05-20-2018, 04:43 PM
Anton Chigurh
Anton Chigurh's Avatar
Location: What's the most you've ever lost on a coin toss?
I always change the oil when it gets around 30%
Quick Reply: What oil percentage do you let your oil get to before changing it out?
