396 vs 427 stock torque
A couple of years back I restored a 1970 GMC with 396 (402). I built it bone stock. On the dyno it peaked at 408 lb-ft of torque, and the GM Heritage documents show the gross torque peak at 400, so very close.
Right now I'm dyno tuning my bone-stock L36 427 and it's making 498 lb-ft down low, tantalizingly close to 500.
First off this seems like a LOT of torque from an L36, is this typical?
Also, why would it make 80lb-ft more than the 396 with only 30 extra cubes? The cam profile in the 427 is better, but is it that much better?
Dr. Detroit
Received 3,891 Likes
The L36 was rated from the factory at 460 or so......but the big deal is the large oval port heads and a somewhat larger cam.......so with some dyno error and a tweak here and there I could see it.
I had a 427/400 that was slightly modified and bored to 440.....it made silly torque.
FWIW....dynos do not record well at very low RPM's.......beware of "popcorn" number where the engine is out torquing the dyno.
About 2500 rpm and up is where you would see accurate numbers.
Jebby
Well....peanut port truck heads with a stock cam really hold back torque.
Jebby
Jebby
Dr. Detroit
Bone stock Truck Big Blocks had the peanut port head.....all of them....even my 454 (468) outside.......they actually work rather well if ported but with a mosquito bite cam....they are disappointing.
If you have a large oval truck motor....I have never seen one....but does not mean it doesn't exist.
Jebby
Dr. Detroit
I just edited my post.....and that may give you more insight.
Jebby
Jebby
I assume they used a small, high velocity port for good low end torque, and yet the 427 makes much better low end torque anyway (more than the cubes alone would account for). Hence the question, I guess!
Or when they say "low end" do they mean way down at 1500 or something?
If I'm not mistaken, this is the truck head on the top and the "oval port" head on the bottom.
Dr. Detroit
I hadn't thought that much about the ports so you could well be right. I know it's a different intake manifold. According to my notes, the heads are casting 3975950 which is indeed a truck specific head.
But anyhoo......the 427 is more efficient.....and that is a good thing.
Jebby
396 bore shrouds even 2.06 intake valves.
Dr. Detroit
Won't effect torque down low really.....not until it needs to breathe.....
383's and 406's make about the same torque down low......but many other factors come into play as well.....too many to list.
.150 of bore size will not make 90 ft/lbs. torque.......of course i have said too much at this point.
Jebby
Jebby
that is one of the old wife's tails. Very dumb one that the uniformed continue to spread. a cubic inch is a cubic inch.
if everything is exactly the same and I just change the bore and stroke. The longer stroker might have some frictional loss... the bigger bore might have some better cylinder filling
It could just be the picture but the heads at the bottom appear to have larger runners. I'm wondering if the torque increase was due to the slightly larger intake runners and slightly larger bore combination. I imagine if you stick the heads in that picture that are at the top on the 427 you will notice some loss of torque from that 498 number.
Definitely I think as Jebby said the truck heads are way worse.
I'm just surprised down low, I thought the high velocity truck heads might fill the cylinders down low much better and win for torque.
But that's not what the dyno says. Perhaps the smaller ports give you better throttle response and driveability, but they're not winning the torque war.
I would hardly call the L36 a "lump" or a "junkyard truck engine" as some on this forum have. After all...it is a 427. We loved them all back in the day for a reason.
I actually think it's the third best factory big block. For driveability and street manners I think the leaderboard is:
1970 LS5 454
1969 L68 427
1969 L36 427
Otherwise you're into mechanical lifters and rectangular port heads, and those heads aren't really the hot ticket for street manners. If they were anywhere near as fast as people think they are they'd be worth it, but they're generally not. So you get crappy cold starts and poor idle and a 13- or 14-second car? No thanks!
I was going to say "What would be even better would be a 454 with a head somewhere between oval and rectangular", but that's pretty much exactly what the did with the ZZ502 and it's "Roval" ports.
For comparison purposes...
Here is the 396 we built a couple years ago for my dad's 65'...
This was with lowered compression (9.8-1), stock square port heads, stock Winters intake, and a 650 cfm carb (this was a mistake due to the model number..)... Also dynoed with stock exhaust manifolds.
Only thing really different is its a hyd roller as opposed to the oem solid flat tappet....
I know we left at least 10hp on the table with the small carb and probably 20-25hp with the stock manifolds...
