1985 won't idle with MAF sensor unplugged.
Hello everyone, I recently purchased a 1985 base model with no modifications and ran into a problem. The SES light was on and the code were 32, 42, and 43. I looked and the EGR valve itself worked just fine but a couple of the vacuum lines were damaged. I replaced them, cleaned the throttle body, put new gaskets on the intake manifold, and put a new distributor cap and rotor on. Afterwords, I went to restart the car it will start but immediately dies. I go to pull up codes, and all I get is 12 over and over again. Any help would be greatly appreciated
Last edited by greenroost14; 05-25-2018 at 03:07 PM. Reason: It was a code 32 instead of 34
34 maf voltage low.
42 and 43 are fuel injection/spark circuits I would say go over what you did and check the wires to the distributor and other connectors.
Egr is fine
Good Luck
Egr is fine
Good Luck
When you renewed the intake gaskets, could you have overlooked reconnecting the brake servo line? I mention this because I did. I had the pipe inserted but but forgot to tighten the fitting nut. The engine would start...but would immediately die.
Looked there, it was reconnected and tightened down. Tripled checked the wiring to the distributor to the spark plugs, all good.
When you unplugged the battery you erased all stored codes. Need to drive to get codes back, then check it. 12 is just the beginning and end test code .
