Thank goodness for run flats
Old 05-21-2018, 08:03 AM
paldogy
paldogy's Avatar
Default Thank goodness for run flats
Hit a huge pothole yesterday and blew out the front tire. Made it home fine and there is still enough air to make it to the tire store tomorrow. I have had both run flat and non run flat but am now convinced
The following 5 users liked this post by paldogy:
FatsWaller (05-21-2018), GARYFINN (05-21-2018), Gbrad (05-21-2018), marinablu67 (05-21-2018), Welker1 (05-21-2018)
Popular Reply
05-21-2018, 08:14 AM
z06clif
z06clif's Avatar
To me the convience has always outweighed the inconvience.
Clif
Old 05-21-2018, 08:14 AM
z06clif
z06clif's Avatar
Clif
The following 7 users liked this post by z06clif:
Bruze (05-21-2018), FatsWaller (05-21-2018), GARYFINN (05-21-2018), Landru (05-21-2018), marinablu67 (05-21-2018), Topdown12 (05-23-2018), Welker1 (05-21-2018) and 2 others liked this post. (Show less...)
Old 05-21-2018, 09:21 AM
919cw313
919cw313's Avatar
Received 2,683 Likes on 1,408 Posts
2018 C6 of Year Finalist
Great story.
Old 05-21-2018, 09:28 AM
Jeff T.
Jeff T.'s Avatar
Received 1,090 Likes on 797 Posts
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Glad you made it home.
I’ll do my best to avoid potholes and run flats.
WW7 (05-23-2018)
Old 05-21-2018, 09:43 AM
GARYFINN
GARYFINN's Avatar
Location: S/W ,Fla-Ohio State Football isn't a matter of life or death,Its Much More serious than that
Received 1,142 Likes on 592 Posts
Run Flats Don't leave home without them
The following 2 users liked this post by GARYFINN:
Bruze (05-21-2018), marinablu67 (05-21-2018)
Old 05-21-2018, 09:57 AM
BADBIRDCAGE
Support Corvetteforum!
BADBIRDCAGE's Avatar
Received 1,963 Likes on 1,055 Posts
If you truly blew the tire out the tire had a catastrophic failure and you don’t have any air pressure in the tire. You can drive it for a while (50 miles advertised at 50 mph) on the thick sidewall of the tire and that is the beauty of the zero pressure tire. You are not on a tow truck or on the side of the road.
Glad for you that nothing is damaged and you can replace a tire and go on having fun with your Corvette.
Old 05-21-2018, 10:13 AM
Bruze
Bruze's Avatar
Received 1,136 Likes on 882 Posts
This is what I was thinking also when I first read his post.
Old 05-21-2018, 10:23 AM
Mcrider
Mcrider's Avatar
Received 1,038 Likes on 400 Posts
Run flat tire on a sports car = tire condom
Vette_DD
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
Had a flat tire with runflats on the interstate after running over an unseen object on 2 different occasions during the 7 years I drove back and forth to see my mother at my sister's house. Sure glad I had them.
Old 05-21-2018, 10:57 AM
JerryC5
JerryC5's Avatar
Cruise-In I Veteran
Cruise-In II Veteran
I had a sidewall cut in New Mexico, and it created a leak. I refilled with air every 200 miles and made it home to Missouri. It was unlikely I would find a vette runflat tire on the reservation. The runflats gave me the confidence I could get to a place where I could get it fixed, and also the confidence that refilling would get me home.
So I am a believer in runflats.
Old 05-21-2018, 11:21 AM
farmington
farmington's Avatar
Received 1,119 Likes on 798 Posts
get the wheel carefully checked. with the low profile tires, if you smacked it hard enough to pop the tire, the wheel probably took a hit too. Keep your fingers crossed that you're only buying a tire
Old 05-21-2018, 12:22 PM
45gunner
45gunner's Avatar
I was doing research on tires as I was replacing the tires on my 2011 Convertible. Somewhere along the line, one article suggested that running a Corvette without run flats was asking for body work if the tire blew and shredded. I have had 4 Corvettes and all 4 have had run flats. To me, they are worth the extra money for peace of mind.
Old 05-21-2018, 12:56 PM
marinablu67
marinablu67's Avatar
Just think, if they made run flat condoms for us, we could go all night without deflating!
The following 2 users liked this post by marinablu67:
astaggs (05-24-2018), Mcrider (05-22-2018)
Old 05-21-2018, 07:42 PM
phileaglesfan
phileaglesfan's Avatar
The fact is if you have any blowout (losing all air at once) you probably won't be able to find a tire for a day or two, but runflats at least allow you to keep going
Old 05-22-2018, 07:49 AM
Cedar
Cedar's Avatar
I need tires for my 11 GS, so I priced both Michelin run flats and non run flats and believe it or not, the run flats were 35.00 cheaper than the non run flats. I didn't know which way to go, but the more I think about it, I'm going to put the 35.00 back into my pocket and buy the run flats for the piece of mind.
Old 05-22-2018, 08:42 AM
Mcrider
Mcrider's Avatar
Maybe I am wrong, but I see the much stiffer sidewall as being counter to the overall design improving handling. The same with acceleration. Watch videos of drag racing and the flex in the slicks under launch.
In 40 years of motorcycle riding and hundreds of thousands of miles, flat tires were never an issue I worried about and I don't understand this major concern about it in a car. Finding a replacement tire, if needed is as close as your Chevrolet dealer.
The entire persona of a sports car is performance and handling. Run flats are counter to both.
Yokesc5 (05-22-2018)
Old 05-22-2018, 09:01 AM
BADBIRDCAGE
Anything you eat, drink or breathe will only sustain you until you die.
Same with tires. Can’t be worrying about what body damage MIGHT occur if you lose a tire on the road. AND there is nothing that says a run flat can not disintegrate under catastrophic failure of the tire.
Be more concerned with your ability to control the vehicle should such an event happen.
To Thank goodness for run flats
Old 05-22-2018, 09:10 AM
Bruze
Bruze's Avatar
. . . waiting patiently for Mrs. Ow to tell her story and post pix . . .
Old 05-22-2018, 09:34 AM
Yokesc5
Yokesc5's Avatar
Stay off the brakes or run flat or not you Will be calling AAA, do they deliver tires, just a thought?
Old 05-22-2018, 11:30 AM
Vet Interested
Vet Interested's Avatar
Received 2,093 Likes on 1,207 Posts
I agree with the above but there is no way in hell I am driving out of state on non-run flats. If I had a local city driver maybe, but I want to get out on the InterSTATE and enjoy my car. I can drive around town in any car.
Quick Reply: Thank goodness for run flats
